#16 (permalink) |
![]() Join Date: Oct 2007
I get 15 - 16, driving around town, and about 19 or so on long freeway trips. The worst I had was 13. And, I have a larger than stock size wheel/tire setup; it was a tiny bit better on the stock wheel/tire setup. I use my AC most of the time. I get hot easily
For city driving, if you floor it a lot, it's like taking the lid off a 64 oz coke and guzzling it. Also, make sure your tire pressure is right, and keep up with the maintenance. A decent quality gas helps also. I was using a cheap gas brand in a Maxima (don't have the car any longer), and it was getting 19, down from 25. When I changed back to a decent brand, it went back up to 25.
2004 Pilot LX | Nighthawk Black | Tint | 18" TSW Mondello's - Hyperblack | 255/55/18 Toyo Proxes S/T |
#17 (permalink) | |
![]() ![]() ![]() ![]() Join Date: May 2007
'04 Honda Pilot EX-L (Redrock Pearl) '01 Toyota Camry LE (Antique Sage) |
#18 (permalink) | |
#19 (permalink) |
![]() ![]() Join Date: Sep 2007
Hi all!
Don't forget that gas is heavy - really heavy. If you drive till your tank is nearly empty before filling up you will be driving at a lighter weight for more miles due to the gas being consumed, than if you keep filling up at 1/2 tank. You will get better milage when lighter. Not a big difference, but the little things can add up.
~2006 Sage Brush Pearl EX-L with Navi ~After market Alpine DVD RES ~Wwong's pads ~Complete interior Superbright LED lighting ~Cargo tray ~50-watt fog lights as reverse lights ~Weathertech floor liners |
#20 (permalink) | |
Not too big a deal. Probably accessories like roof racks, fender flares, running boards, etc. are as big a weight hit and have aerodynamic effects also.
#21 (permalink) |
![]() Join Date: Aug 2007
I usually go with 87 octane, the C grade stuff. But last time I filled up (several days ago, at least) and before that, (like two or three days before last time) I used 89 Octane.
I've got about half a tank left, give or take. I have done solely city driving for the past 10 days-2 weeks. My A odometer says about 150 miles or so driven on it. The last time I reset it I had about 3/4 of a tank. I think I can get pretty good gas mileage. Usually 20 to the gallon.
2007 4x4 honda pilot. that's it. i've driven an '05 Acura MDX, ask me they compare well, except the pilot drives like it should - like a truck, the mdx, a car. I have a steel blue 2007 4x4 EX-L. navigation, back up camera and it came with roof racks. I'm into off-roading with the Pilot. anyone else? |
#22 (permalink) |
First off, all these nifty little secrets to save on gas consumption sound great... but they really don't affect your gas mileage that drastically, unless you become the most anal driver out there. I abuse the heck out of my pilot (70 miles a week on rough, hilly, unpaved road), and see, maybe a 10 to 20 mile difference between my city and highway mileage, which really isn't much. I can imagine any vehicle is exposed to lots of road salt in New York, and I'm sure the 03 Pilot in question has a few miles on it... so I'd suggest an inspection of the before catalytic converter O2 sensor. A dirty O2 sensor will affect your gas mileage dramatically. Someone tell me I'm wrong... I dare you!
#24 (permalink) | |
You can get noticable impressionists with some driving changes, and other changes require "anal" behavior. As for the O2 sensor, if it is bad, you will get bad mileage, but it seems in most cars today, you will get a check engine light also. I would not expect changing it before the light comes on to give any significant benefit.
#25 (permalink) |
You typically will not get a check engine light until the sensor fails. In the mean time, as with dirty oil filters, fuel filters, air filters, the O2 sensor may cause perormance issues on the vehicle. If you know anybody with any mechanical know-how, it wouldn't hurt to have them pull it off and remove any build up or debris that may have collected up in there.
#26 (permalink) |
I think to be sure that your pilot is fine ,try do the folllowing :
Take your car to dealer and ask them to connect the laptop to the ODB2 port (under the dash) , the special software will analyze your car and print for you an advance report about and including emmitions , Fuel , O2 etc... sensors...readings ...etc... by that you will be sure 100 % that your engin is fine or not or need fine tune or you should change your driving style. Remember i used to get 10 to 11 MPG in city drive with 8 traffic signals and for 6 KM only daily. Pilot is very sensitive to style of driving and stop-and-go driving. Hope the above help Wissam Beirut City -Lebanon |
