![]() ![]() ![]() ![]() Join Date: Nov 2006
Two things surprised me when looking at the Pilot Service Manuals:
1) The i-VTEC engine in the 2WD Pilot does not have variable valve timing -- it has VCM (Variable Cylinder Management). The 4WD Pilot has variable valve timing. 2) The Pilot does not have a Mass Air-flow (MAF) Sensor. i-VTEC means many things, depending on the model of the vehicle -- on some models, i-VTEC does have variable valve timing, but on the Pilot 2WD in 2006 it doesn't. Fuel Injection systems with a MAF are generally considered more accurate. With a MAF sensor, the air ingested into the engine is measured directly by the sensor -- no calculations are needed to determine the air ingested. Systems without a MAF, but have a MAP sensor and an Intake Air Temperature sensor (along with other sensors), usually calculate the air ingested from these sensors -- this is known as a "speed density" system. Speed is determined by the RPM and Density is calculated mainly by the intake manifold vacuum and intake air temperature. The point is: a MAF system is usually considered more accurate in determining the amount of fuel to inject to mix with the air because there are less calculations needed. However, the Pilot is considered a low-emissions vehicle. Many, if not most, other manufacturers went from Speed-Density to MAF for lower emissions. But, the Pilot didn't do this. I wonder why. |
#2 (permalink) | |
![]() ![]() ![]() ![]() ![]() Join Date: Jan 2007
Chris
2007 Pilot EX-L 2WD Desert Rock Metallic Goodyear Fortera SilentArmors wwong's pad set Audio: Kicker ZX700.5, Polk db6500F/650R, MTX T4510 sub, Dynamat Extreme+Second Skin Damplifier, Navone 4-channel LOC w/ stock head unit |
This is one of hundreds of complicated engineering tradeoffs made in the design of an engine. Either system can do the job fine. MAF systems are generally superior in their ability to adjust to engine modifications, but in the Pilot, Honda figures 98% of engines remain bone stock so it probably matters little. MAF tend to have a small amount of intake restriction so that's a minus.
With a closed-loop system and multiple O2 sensors, you can get a speed density system to meet very stringent emissions requirements and it probably costs less. - Mark |
Re the ULEV - my 2007 4wd has is a ULEV vehicle. My 98 civic is just a LEV. Interesting that they can improve an engine so much (from civic to pilot) and it get better emissions while making much more power.
(i know the engines are different - pilot is twice as big and all that, but it is still interesting what they can do nowadays)
2007 EXL RES 4wd - Aberdeen Green (awesome color) <div><p><img src="http://i46.photobucket.com/albums/f120/Konechiwa/john_c__reilly10.jpg" hspace="5"></p></div> |
MAF based systems are better for tuning but the sensors used can have a short life span. CEL, trip to service, $150-250 bill, unhappy customers. I tune turbo VW's, the simplicity and low maintenance of the Pilot gives me more time and money for the VW!
2003 Honda Pilot EX |
Current: 2008 4WD EX-L NAV - OEM Tow Package - OEM Running Boards - Sirius conversion using OEM headunit and antenna - Vizualogic A-1250 Dual DVD Headrests - RGB converter for DVD on NAV screen - Hitch-Haul - Air Lift 1000 - USA-Spec PA15-HON2 - DEI 452T Auto Locks Old: 2005 EX-L NAV - Vizualogic headrests - RGB converter for DVD on NAV screen - DMP1 MP3 player - Sirius Starmate Replay - PIE X3 interface - OEM Tow Hitch & Trans Cooler - OEM Running Boards - Hella FF50s - Cross Terrains |
