vtec - Honda Pilot - Honda Pilot Forums
Old 06-07-2006, 08:06 PM   #1 (permalink)
Default vtec
at what rpm does the vtec "kick in" on our pilots?
I've heard 4500rpm...?
I know there's not a huge surge in power at the changeover point like with DOHC vtec engines, but the tone does seem to change around 4500.
2006 LX 4WD
20% Tint
(Now the wife's ride)
2006 VW Passat 2.0T
APR Tuned
slugmike is offline   Reply With Quote
Old 06-08-2006, 07:08 AM   #2 (permalink)
xGS
xGS's Avatar
Default Re: vtec
Quoting from hondanews.com:
VTEC Valvetrain
Honda's innovative Variable Valve Timing and Lift Electronic Control (VTEC) technology helps to maximize performance across the engine's full operating range. The VTEC system has two distinct modes to optimize both volumetric efficiency (breathing) and combustion of the fuel-air mixture. Less air is needed in the lower portion of the engine's operating range so rocker arms are programmed to follow cam lobes with a lower lift profile and reduced duration (shorter time open with less valve lift). The two low-speed intake cam lobes for each cylinder are purposely different to provide asymmetric air/fuel mixture flow into the cylinder. This yields a swirl effect that improves combustion efficiency for better performance, fuel efficiency and reduced exhaust emissions.
At 4300 rpm, a control module directs the VTEC system to switch intake valve operation to the high-speed mode. An electric spool valve opens to route pressurized oil to small pistons within the intake-valve rocker arms. These pistons then slide to lock the three rocker arms together. As a result, both intake valves follow a central high-lift, longer-duration cam lobe. The switching process takes just 0.1 second and is undetectable by the driver. The extra lift and longer duration provide the added air and fuel the engine needs to produce high peak horsepower and a broader torque band.
Old 06-08-2006, 08:23 AM   #3 (permalink)
mgorbsk's Avatar
Default Re: vtec
I've never heard it in either the Pilot, or the Accord. I've also never felt it in the Pilot and don't know if I've ever taken it to 4300rpm. I can tell you I've definitely seen higher rpm in the Accord EXV6 Coupe and definitely feel when it kicks in. It's pretty fun to drive it.
04 EXL-RES (Redrock Pearl)
98 Accord EX-V6 Cpe (Black) Traded In
08 Toyota Tundra CrewMax 5.7 4x4 (Desert Sand)
mgorbsk is offline   Reply With Quote
Old 06-08-2006, 02:45 PM   #4 (permalink)
HondAficionado
My civic has a cold air intake kit, so the only thing I notice is the change in the sound when it kicks in. I dont think I feel it at all... but then maybe if it wasnt there I would feel the difference
NEW: 2011 Pilot Touring in Bali Blue. No goodies yet!
OLD: 06' EXLNR 4WD Pilot in Metallic Blue
Add-ons:
~Panasonic 9" overhead DVD~Ipod port~Honda cargo tray~Full size spare~Cargo area net divider for pooch~Xtreme catch all mats~sunroof visor~Exhaust finishers~rear spash guards~3M lens protector on headlights & fogs~Wwongs pad set!~"STILES" Rear Subframe Brace Retrofit Kit~Kicker replacement speakers throughout ~ and A Double coat of Meguires best!
2muchfun is offline   Reply With Quote
Old 06-08-2006, 03:54 PM   #5 (permalink)
The VTEC systems in SOHC engines are setup mainly for fuel economy, so you don't get that semi-dramatic power shift that you do in the DOHC engines.
Old: 2005 EX-L NAV
Old 06-08-2006, 04:41 PM   #6 (permalink)
Default Re: Re: vtec
VTEC Valvetrain
Great info, thanks!!
2006 LX 4WD
20% Tint
2006 VW Passat 2.0T
APR Tuned
Old 06-08-2006, 04:55 PM   #7 (permalink)
ecsw's Avatar
4300rpm? I remember my TSX was at around 5400rpm. Guess it's different between V6 and i4 and DOHC and SOHC then.
2006 Black Pilot EX-L w/ NAVI
2008 Mazda Ti-Grey RX8 GT 6MT
2004 PWP TSX (Sold)
Old 06-08-2006, 09:30 PM   #8 (permalink)
Definitely hear that change in the engine note around 4500. Hell I do it coming out of toll booths for fun every so often.
I love this engine
Old 06-08-2006, 10:49 PM   #9 (permalink)
HondAficionado
Thanks for the info.
Now I have to go out and stomp on the Pilot to see what happens
Add-ons:
Old 06-26-2006, 02:53 PM   #10 (permalink)
brianmsmith's Avatar
Yet another reason to fit the K&N filter - the sweet sound at higher revs.
Brian M Smith - 05 EX Desert Rock # 44029
Goodyear Fortera 245/60-16 - PIAA Xtreme whites - separation net - brake light cover
Wilson's widgets - Pilot SS tips
Auto day/night mirror - Westin brush bar (black) - Hella Black Magic lamps (finally)
K&N air and oil filters (33-2200 & HP-1010) Passport 8500 X50 - Next?
brianmsmith is offline   Reply With Quote
Old 06-26-2006, 11:05 PM   #11 (permalink)
is there a noticeable change in the sound with just a drop-in k&n filter?
2006 LX 4WD
20% Tint
2006 VW Passat 2.0T
APR Tuned
Old 06-27-2006, 12:25 AM   #12 (permalink)
No... unless you open up the airbox.
Old 06-27-2006, 08:11 AM   #13 (permalink)
ctobio's Avatar
I love performance as much as the next guy, but who cares what the sound of the intake is?
Does it work? Does it work well? Can it be made better (without serious detriment to other systems)? That's my criteria for how I feel about a modification.
How it sounds frankly ranks pretty low in my opinion. Unless its a stereo.
That said, A K & N filter will not likely change much of the intake tone. It never has in any of the other cars I've had.
I tend to lean nowadays away from K & N filters. I don't think they provide much benefit, and maintained improperly they will do more harm than good. In normal daily driving, a paper filter will do just fine so long as its changed with reasonable frequency. I rarely follow the manufacturer's guidelines on this. I usually change more frequently, based on a visual inspection.
Constantino Tobio
Vehicles in the driveway:
'73 VW Fastback, Marina Blue
'94 John Deere LX176
Old 06-27-2006, 09:13 AM   #14 (permalink)
Well, actually I beg to differ. I can hear a distinctly deeper/raucous note above 3000 rpm after the K&N had been in for ~5000 miles. This may be coincidence, it could be the engine becoming fully run in (15,000 miles). However, the K&N master distributer here told me from the outset that the engine WOULD sound different after a few thousand miles of K&N use. I won't go into efficiency again, that was dealt with exhaustively a month or so ago. Just suffice to say the K&N filter does what I want of it - lets the engine breath better - and filters enough for me. The changed sound is a little bonus; I don't like noise but I do appreciate sound, especially a fine engine on song.
Old 06-27-2006, 09:17 AM   #15 (permalink)
jay
jay's Avatar
I appreciate a fine song without any engine noise.
