#2 (permalink) | |
(the other one)
The Fleet; 04 EX-L Pilot, Sage Brush Pearl: Chrome Steps, Crossbars, OSRAM "Night Breaker" bulbs, Auto Day/Night Compass Mirror, Cargo Tray, Rear Splash Guards, LED Marker/Signal Light Bulbs and interior bulbs, SS Tips, WWong's pads and a Garmin c530. 01 Nissan Maxima SE, In Leather, 5-Speed, (the fun car), Silver: PIAA Super Extreme White Headlight Bulbs, LED Marker/Signal Light Bulbs The Loonie Twins; (Two) 04 Toyota Corolla LE's , 1) Moonshadow Metallic, 2) Lunar Mist Metallic, side bags, anti-lock brakes and (of coarse) LED interior/exterior bulbs www.albinoblacksheep.com/flash/posting.php |
any specific problem you're referring to? I haven't had any problems, but then again I've only had the pilot for less than 3 weeks.
Current Hondas: <FONT COLOR="#000000"><B>2006 Honda Pilot 4WD EX-LN</B></FONT> <FONT COLOR="#999999"><B>2004 Honda S2000</B></FONT> |
I don't think thin is any problem with sensors - the MAF measures the same air whether it is downstream of an OEM paper filter or an oiled foam or gauze filter.
But... despite all the planted propoganda on the net, these filters just don't filter as well as OEM paper. Whizmo |
hey yea thanks for your input but was looking for how the mas worked with such a setup.and why are you in this forum again what experience do you have with performance.please do tell. or a6 pilot have you fallen for the tornado since you show no intelligence in performance but to mock others
I have tried the K&N filters several times and always had the same experience.
- they start off great seem to help performance etc, but quickly gum up and then I was never able to get them clean again like they were the first time, (even trying K&Ns proclaimed filter cleaner). I have since gone back to OEM filters and just toss them out a regular intervals and always clean them off and vaccum out the air intake when I change the oil. If I was a race car driver and used it for 3 hours and then tossed it out, I am sure they would be great, but Im not so I dont... |
I think he was kidding, you know, good natured kidding. Geez.
The "success factor" of a K&N filter depends totally on the specific vehicle you use it on. I've used a K&N replacement (non- FIPK) filter on the following:
- 95 Saab 900 - big difference vs stock - you could feel it at all RPM ranges - 03 Pontiac Aztek - no difference vs stock - 01 Chevy Tahoe - noticable difference at low-rpm performance, not so much as you get the engine happier I will disagree about the "gumming" up of a K&N - I drove each of the above for 30-40k miles, and while they did get dirty, their performance never suffered, and cleaning it with the K&N kit (with the aerosol oil, NOT the bottle of oil) did the trick. I think the reason folks have trouble with these is that they put too much oil on the gauze. You put just enough oil with the spray to give the gauze a pink tint and stop. Any more and you create a gummy/oily situation where you could possible start clogging it up a bit.. When oiled correctly, you don't impact any electronics downwind from the filter. andy
#12 (permalink) | |
More evidence for the placebo effect.
chazexl-
I was only half kidding. Please check out the following link, and see if you can still recommend a K&N filter. http://home.usadatanet.net/~jbplock/ISO5011/SPICER.htm |
#14 (permalink) | |
go figure... andy
#15 (permalink) | |
Lets see the paper is restrictive to low flow rates, but gets better at high rates? I'll give you a little hint; All the "improvement" felt, is a result of how your brain interprets the noise!
