18 or 19 inch wheels? - Honda Pilot - Honda Pilot Forums
Old 07-02-2011, 11:00 AM   #1 (permalink)
Default 18 or 19 inch wheels?
hey piloteers members,
I had a flat recently and was thinking about replacing all the wheel on my 2007 honda pilot?
Can you kindly confirm what is the factory bolt pattern and wheel spec on a 2007 honda pillot?
I am deciding to with either a 18 inch rim or 19 inch rim and was wondering what are the PROs and CONs or going to 19?
I like the ENKEI FALCON rims and there specs for it, is attached, what do you think about thew wheel? will it support the honda pilot weight? Any comments are welcome. I also don't mind acura wheels, so if anyone has any recommendations, please feel free to drop a response.
THANK YOU,
Leo
18 or 19 inch wheels?-enkei_falcon_silver_large.jpg   18 or 19 inch wheels?-enkei_falcon_size_chart-672x484.jpg
leo38cheng is offline   Reply With Quote
Old 07-02-2011, 11:14 AM   #2 (permalink)
Have you done a search and reviewed others experience with these sizes? Search stud spacing and backspacing as well.
Old 07-02-2011, 02:35 PM   #3 (permalink)
thanks for your response. I see that the spec for the factory 16 rims for the 2007 honda pilot is:
Pilot's wheel size is 16 X 6 1/2 JJ, bolt pattern is 5 X 114.3 mm, offset is 45 mm.
can anyone tell me what is the affect of an offset that is 40 instead of a 45?
thank you.
