Thinking about installing the sparkling sivler 19" RDX wheel on my 2006 Honda Pilot and was wondering if anyone that has this had any issues with MPG's or traction. We live in Louisville, KY so some winters we may get zero snow and the next winter we could get 12". I don't want to have to have 2 different wheels for summer and winter driving. As you can tell I am more concerned with traction than MPG's but would like the forums opinion on both. Thanks in advance for any advice.
Any of the tires including the magic words "All Season' will do fine. Eg highway all season, Grand Touring all season. But after trying various brands over the years would stick with Tireracks, OE tire the Michelin
Michelin Pilot HX MXM4
From my experience, generally speaking, if you increase the size of the wheels, the tire sidewall size goes down, so there's less sidewall flex and less of a contact patch between the tire and road. This is made worse when the tire manufacturers recommend running the lower profile tires at a higher PSI to avoid damaging the shorter sidewalls. It's not a huge difference, but it's a difference. In most cases, the contact patch area that is lost front to rear is made up in width by running slightly wider wheels and/or tires.
