I am looking to put some 245/75-16 on stock rims for my '04. I saw the width is the same as stock size except the overall diameter is about 1.5" more than stock. Do you think they will rub on turns or over road bumps?
Thanks for all inputs and below is the link of the tire I'm loking at: Kumho Road Venture SAT KL61 |
The search button is your friend. Plugging your requested size into the search box and all is revealed.
Largest Off-road size on stock 16's?
245 is not the stock width on 03-08 Pilots.
I have the 245"s and they are fine, in fact 245 is your second option on the pilot...
"Sogood" HONDA PILOT LX "07 Upgraded my sound system 100%,with Polks comp-speakers,2 15"L7's and ZX2500.1, ZX850.4. Got two Kinetik batteries and a digital Volt meter made by Stinger (which doesn't work well). 3" HID's kits 6000k, lowbeams, Oem fog lights and,aftermarket foglights. OEM foglight install by me,cross bars.Limo Tint windows, splash guards,steering wheel protector..Etc,etc,etc. |
But what about the 75% aspect ratio part of it? From the link of that white Pilot the 245/75-16 looked pretty "tight" around the wheelwell that looked if it cannot take a big bump or bumps while turning. Anyone has experience with 245/75-16 tires to share?
The 245/75/16 tire is larger in overall circumference and diameter than the 235/70/16.
Therefore the tire will rotate less revolutions from point A to point B. That means your speedo cluster will read SLOWER than actual speed and your odometer will register less miles than actual mileage. Without doing the actual math, I am guessing that your speedo = 65 and actual = 70 with the new tire size. Could be an issue if ever pulled over for speeding. This can be verified by a GPS unit or with those radar speed signs on the side of the road.
'04 EX-L, Alabaster Silver Metallic, front bumper lower trim, OE fogs w/yellow H3 bulbs, OE running boards, OEM tow package, backup sensors, Alpine CDA-9887, Alpine PDX-5, Polk Audio SR6500, Alpine Type R 10 inch shallow sub in factory location, Compustar security with remote start. |
When speedometer reads 60mph actual speed will be 63.1mph.
Wheel / tire size calculator / comparer - RIMSnTIRES.com |
