I have an '05 Pilot with the VTM-4 AWD system. Blew out one rear tire that is not repairable and would like to know if I can replace just the two rear tires instead of buying 4 new ones. Would appreciate feedback.
How worn are the old tires.
If they are very good, just replace the one. If they are fairly good, replace a pair. If you are picky you can run the new tires two PSI lower then the old set (keeping all tires above the minimum PSI) If they are getting old, it is best to replace the set. No matter what you do, stay up with rotating the tires.
