Largest Off-road size on stock 16's? - Honda Pilot - Honda Pilot Forums
Old 09-08-2010, 12:10 AM   #1 (permalink)
Send a message via ICQ to Cheeky Send a message via AIM to Cheeky Send a message via Yahoo to Cheeky
Question Largest Off-road size on stock 16's?
Trying to get a more aggressive off-road look and feel to my Pilot, what would be the largest size tire I should go with on the stock 16's? Was thinking about 255/70R/16 from BFGoodrich but wanted some opinions?
BFGoodrich All-Terrain T/A KO
Largest Off-road size on stock 16's?-bfg_alterr_tako_ci2_l.jpg   Largest Off-road size on stock 16's?-bfg_alterr_tako_ci1_l.jpg   Largest Off-road size on stock 16's?-bfg_alterr_tako_ci3_l.jpg
Cheeky is offline   Reply With Quote
Old 09-08-2010, 09:39 AM   #2 (permalink)
If by Large you want width then 255 is the largest size people have put on first gen Pilots. However they used a lower aspect ratio to maintain the same overall diameter of the tire.
One person did use 245/75-16 with no reported clearance issues.
Pilot on 245/75 16"
The extra 10mm width isn't much- not even half an inch- but is it enough clearance? The 245s look awfully close to the inner fender
thinking about using 255/65/16
A search reveals the following thread:
Tallest Tires?
Getting friendly with the search function of a forum is a great thing to do
Old 09-08-2010, 09:46 AM   #3 (permalink)
Supposed to fit. 255/70/16 255/70/R16 DO fit on a Pilot
Just be a little careful and make sure the tires you select don't have too much tread on the sides that is not in the tread-width measurement. Some "truck" tires have some extra tread that I don't think is included in the measurements.
Old 09-08-2010, 09:57 AM   #4 (permalink)
And don't forget that larger tires reduce your torque.
Old 09-08-2010, 12:01 PM   #5 (permalink)
Larger tires do NOT reduce engine output either BHP or Torque.
However larger tires do affect gearing with the engine revving lower down in the range for any specific speed.
Old 09-08-2010, 12:39 PM   #6 (permalink)
Sorry, they lower effective torque as applied to moving the vehicle.
Old 09-08-2010, 09:47 PM   #7 (permalink)
Pilot on 245/75 16"
Tallest Tires?
Thanks Rocky, I thought I posted the year but I'm a 2nd Gen Pilot 2006 EX NAV. Would it being 2nd Gen make any difference?
