18 x 9 rim fit? - Honda Pilot - Honda Pilot Forums
Old 08-12-2010, 01:56 AM   #1 (permalink)
Default 18 x 9 rim fit?
Anybody know if an 18x9 inch rim with a 35 offset will fit our pilots without rubbing issues?? Stock is 16x7? or 16x8? Was thinking of an 18x9 inch rim with a 245 or a 255/65/18 tire....
blackdragon is offline   Reply With Quote
Old 08-12-2010, 03:27 AM   #2 (permalink)
Stock rim is 6.5. (03-08MY)
I went through the sticky of wheels and tires, and found many links to threads with a similar set up to what you are thinking. You'll probably find many more if you go hunting.
BTW: any thread that has hondapilot.org, change it to piloteers.org and the thread will pop up
18" wheels with 255/55/18 tires just installed
and this one
18" Wheels
here are the RDX wheels. dunno about width thought
18" RDX wheels
Old 08-12-2010, 11:35 AM   #3 (permalink)
krazykarguy's Avatar
What is the stock offset for the '03-'07 Pilots?
Old 08-12-2010, 11:47 AM   #4 (permalink)
RSQ Pilot's Avatar
Garage
Wheel size: 16X6.5”-Bolt pattern:5X114.3 mm – Offset:45 mm
Old 08-12-2010, 12:52 PM   #5 (permalink)
Killer. Thanks!
