I have a set of CT's on my 2003 Pilot which are approaching replacement. I had to replace one after about 25K because of sidewall damage. It was placed on the rear passenger side, and now has about 15K on it. When I last went to Costco for a repair and rotation, they would not rotate the tire to the front, citing the impact of uneven size on the primary drive wheels. I'd like my best tires upfront. Is this a real concern or overcaution? Thanks.
If you have significant wear on the set, it is usually recommended to replace a pair when one tire is damaged.
agreed.
I agree with that too. But until I have my personal TARDIS to go back and rectify that decision, I still need to decide if I can rotate that tire to the front. Any safety or mechanical issues I should consider before deciding?
How different are the tires?
If you only have 15K on it, maybe go get another one.
I am planning on going all new before Winter, probably with Lats, so a one tire purchase doesn't make sense right now. Just trying to get through the summer driving season with the best set-up. I'll probably keep the newer CT as the spare.
Mike:
Call it lawyers caution. Surprised they even noticed.
#11 (permalink) | ||
It is to extend the life of a set of tires. If you don't care about getting the longest possible life from the tires as a set, it matters less.
So rotating is much like replacing in pairs. Quote:
In general, I would have put the new tire on the wheel that wears the fastest, and continue with the rotations. You could put it up front (to increase wear) and then swap it back and forth while rotating the others among the three remaining positions until the tires are indistinguishable in wear.
Mike: I had the SAME exact experience at our (Grand Rapids, MI) Costco two weeks ago. Took our 2003 (Michelins) in for rotation. The r-r tire had been replaced because of a sidewall puncture, the fronts had more wear than the back. Picked up my key with the job supposedly done, but after inspection, I realized they had NOT rotated them -- and not told me. Confronted the manager who said there was too much wear difference and Costco's policy was to leave best tires on back, and something about loss of stability in emergency maneuvers.
StuGee - there may be something to that. I am reprinting a TireRack article here which, although directed to hydroplanning, could be true of general handling too.
"Most vehicles are equipped with the same size tire at every wheel position. Ideally all of these tires should also be of the same type and design, have the same tread depth and be inflated to the pressures specified by the vehicle placard or owner's manual. This combination best retains the handling balance engineered into the vehicle by its manufacturer. However due to a front-wheel drive vehicle’s front tires' responsibility for transmitting acceleration, steering and most of the braking forces, it's normal for them to wear faster than rear tires. Therefore if the tires aren't rotated on a regular basis, tires will typically wear out in pairs rather than in sets. And if the tires aren't rotated at all, it's likely that the rear tires will still have about 1/2 of their original tread depth remaining when the front tires are completely worn out. Intuition suggests that since the front tires wore out first and because there is still about half of the tread remaining on the rear tires, the new tires should be installed on the front axle. This will provide more wet and wintry traction; and by the time the front tires have worn out for the second time, the rear tires will be worn out, too. However in this case, intuition isn't right...and following it can be downright dangerous. When tires are replaced in pairs in situations like these, the new tires should always be installed on the rear axle and the partially worn tires moved to the front. The reason is because new tires on the rear axle help the driver more easily maintain control on wet roads since deeper treaded tires are better at resisting hydroplaning. Hydroplaning occurs when the tire cannot process enough water through its tread design to maintain effective contact with the road. In moderate to heavy rain, water can pool up in road ruts, depressions and pockets adjacent to pavement expansion joints. At higher speeds, the standing water often found in these pools challenges a tire's ability to resist hydroplaning. Exactly when hydroplaning occurs is the result of a combination of elements including water depth, vehicle weight and speed, as well as tire size, air pressure, tread design and tread depth. A lightweight vehicle with wide, worn, underinflated tires in a heavy downpour will hydroplane at lower speeds than a heavyweight vehicle equipped with new, narrow, properly inflated tires in drizzling rain. If the front tires have significantly less tread depth than the rear tires, the front tires will begin to hydroplane and lose traction on wet roads before the rear tires. While this will cause the vehicle to understeer (the vehicle wants to continue driving straight ahead), understeer is relatively easy to control because releasing the gas pedal will slow the vehicle and help the driver maintain control. However, if the front tires have significantly more tread depth than the rear tires, the rear tires will begin to hydroplane and lose traction on wet roads before the fronts. This will cause the vehicle to oversteer (the vehicle will want to spin). Oversteer is far more difficult to control and in addition to the initial distress felt when the rear of the car starts sliding, quickly releasing the gas pedal in an attempt to slow down may actually make it more difficult for the driver to regain control, possibly causing a complete spinout. Experience Members of Tire Rack team had the chance to experience this phenomenon at Michelin's Laurens Proving Grounds. Participants were allowed to drive around a large radius, wet curve in vehicles fitted with tires of different tread depths -- one vehicle with new tires on the rear and half-worn tires on the front and the other with the new tires in the front and half-worn tires on the rear. It didn't take long for this hands-on experience to confirm that the "proving grounds" name for the facility was correct. The ability to sense and control predictable understeer with the new tires on the rear and the helplessness in trying to control the surprising oversteer with the new tires on the front was emphatically proven. And even though our drivers had the advantage of knowing we were going to be challenged to maintain car control, spinouts became common during our laps in the car with the new tires on the front and the worn tires on the rear. Michelin advises us that almost every driver spins out at least once when participating in this demonstration! Experiencing this phenomenon in the safe, controlled conditions of Michelin's Laurens Proving Grounds rather than in traffic on an Interstate ramp in a rainstorm is definitely preferred! Recommendations Tires should be serviced periodically following the rotation patterns provided in the vehicle's owner's manual or as established by the industry to help enhance wear quality and equalize front-to-rear and side-to-side wear rates. The minor differences in tread depth between tires that might be encountered immediately after periodic tire rotations at 5,000-7,500 mile intervals won’t upset the vehicle's hydroplaning balance and should not preclude rotating tires. For that matter, any differences in wear rates actually indicate that tire rotations should be done more frequently. Ideally tires should be replaced in complete sets. However when tires are replaced in pairs, the new pair of tires (assuming the vehicle is equipped with the same size tires all of the way around) should always be installed on the rear axle and the existing partially worn tires moved to the front axle. While insufficient tire rotation intervals and/or out-of-adjustment wheel alignment angles often caused the differences in front-to-rear and side-to-side tire wear rates in the first place, the need to keep deeper treaded tires on the rear axle to resist oversteer conditions caused by wet road hydroplaning is important. Unfortunately this precludes the future possibility of ever rotating tires. Once a pair of tires has been installed, the only way to escape being forced to drive on mismatched tires continually is to install a complete set of new tires (especially on front-wheel drive vehicles)." |
Interesting. Good to know the Costco tire manager wasn't *completely* full of beans. More frustrating: When I've previously tried to have these tires rotated there, there was never time because of the back up of new tire installs, or too close to closing time to do a 5-minute job.
