Aftermarket rims / lug nuts - Honda Pilot - Honda Pilot Forums
Old 05-10-2010, 09:04 PM   #1 (permalink)
Default Aftermarket rims / lug nuts
When you guys swapped your wheels out for aftermarket rims, were you able to use your factory lug nuts? Or did you have to get aftermarket lugs?
richd978 is offline   Reply With Quote
Old 05-10-2010, 11:33 PM   #2 (permalink)
Just depends on the new wheel. Might work, might not.
Old 05-12-2010, 05:32 PM   #3 (permalink)
Honda uses a ball lug where you will find the majority of all aftermarket rims use a cone lug.
I could not use the factory lugs on my aftermarket rims.
sand wedge is offline   Reply With Quote
