Full Size Spare Tire Rot? - Honda Pilot - Honda Pilot Forums
Old 03-30-2010, 08:27 AM   #1 (permalink)
Pilot-Matt's Avatar
Default Full Size Spare Tire Rot?
I like many members here went with a full size spare change-out several years ago. My spare is now 5 1/2 years old.
Some tire manufacturers recommend changing out the spare tires after 6 years due to age and dry rot issues. I haven't checked the date stamp on my tire yet.
Has anyone done this yet or considering this?
04' Sage Brush Pearl EX
Chrome Side Steps (OEM), Rear Splash Guards (OEM), Cross Bars (OEM), Chrome Exhaust Tips (OEM), Cargo Net (OEM), All-Season Floor Mats (OEM)
WeatherFlectors from WeatherTech (Dark), FormFit Air Deflector, Cloud-Rider Mirror SS Mesh Grille Inserts, Full Size EX Spare, 3m Protective Tape, Wwong's Pilot Pads, Chrome Accessory Logos, Clear Door Edge Guards.
Free brushless car wash anytime.
09' Honda Ridgeline RTL, Mocha w/Black Interior
99' Honda Shadow ACE 1100C2
Pilot-Matt is offline   Reply With Quote
Old 03-30-2010, 09:42 AM   #2 (permalink)
The other question is when was the last time you checked the tire pressure on your spare......
Old 03-30-2010, 10:02 AM   #3 (permalink)
Pilot-Matt's Avatar
I haven't seen my spare since I put it under my Pilot 5 1/2 ago
Old 03-30-2010, 05:47 PM   #4 (permalink)
RSQ Pilot's Avatar
Garage
Default Re: Full Size Spare Tire Rot?
Why let a full size spare potentially rot away and never get any use out of it?
I run a 5 tire rotation program on all vehcles I've owned that are the designated road/tow warriors. That elimiates the problem of never seeing the spare and I get some payabck in overall tread life for the cost of the full size spare (and matched wheel if needed). At the end of that cycle I decide put 4 new on and keep an oldie as a spare or 5 new...generally if I plan to trade it off before the second set go I go back to the 4 new tire sequence.
City commuters gets the 4 tire rotation and a donut pressure check at least at each rotation to ensure the 60 p.s.i. level.
YMMV
Old 03-30-2010, 11:25 PM   #5 (permalink)
My full size spare is actually one of the original tires from my 05. So I guess it's over 5 years old now. Since you've brought this to my attention, I will replace the spare when I replace my current set of 4. I don't drive tires down to the wear bars, so I'm okay with just putting the best one on the full size spare. That will keep my cost down to $20 or so and keeps my spare from being super old.
Thanks.
Old: 2005 EX-L NAV
Old 03-31-2010, 06:55 AM   #6 (permalink)
krygny's Avatar
I also have an OEM Goodyear as a spare. I always intended to replace it with one of the current tires, whenever I buy my next set. Problem is, they're Goodyear TripleTreds, which are directional. So it would only be good for one side of the car.
Now, let me see - on which side of the car will I get my next flat?
2003 EX-L, Sage Brush Pearl
Old 03-31-2010, 07:46 AM   #7 (permalink)
The FS spare I bought had a brand new GY integrity on it.
At least is bi directional...
Old 03-31-2010, 11:40 AM   #8 (permalink)
evarsallona's Avatar
Location: Evergreen Valley of San Jose area of California
Garage
Send a message via Skype™ to evarsallona
Default Simple Maintenance
That’s why some times you see people standing next to there cars on the side of the road with a flat tire scratching there asses.
Simple Maintenance and safety tip
Ever time I do my own oil change, I do a visual inspection of the whole under carriage , that includes the spare tire plus the air pressure too.
That's the reason why I have it stored facing down, for easy access to the valve stem
January '06 Honda Pilot EX-2WD Metallic Silver
Grille inserts/Turn signal mirrors/All side windows tinted/Auto door locks/Hand brake audio warning/Dash mat/Auto mirror/compass//Carpet and rubber mats/Side rails/rear over load shocks/Cargo tray/Net/Cover/Roof rack cross bars/carrier Tray/Lock gas cap honda key/Michelin C/T tires/Wheel locks/Valve caps honda logo/Splash guards/Full size spare/Frame braces/EX & V6,vtec.Emblems/Towing package/Hitch carrier/Bumper guard/Rerouted exhausts outlet.
evarsallona is offline   Reply With Quote
Old 03-31-2010, 03:40 PM   #9 (permalink)
If you mostly drive in the left lane, have it mounted for the left side. If you drive in the right lane, mount it on the right side. I know that's not very scientific and you still have a 50% chance of being wrong, but even then I wouldn't worry about running it backwards for awhile. It's still better than using the donut
Old: 2005 EX-L NAV
Old 03-31-2010, 07:06 PM   #10 (permalink)
Pilot-Matt's Avatar
I'm running Triple treds and my spare is an OEM Intergity.
Old 04-16-2010, 01:09 AM   #11 (permalink)
is there directions are where and how to get a full sized spare? i dont see the rectangular being able to get through the oem rim to put under the pilot?
2008 4wd honda pilot vp black
tripleheetheet is offline   Reply With Quote
Old 04-16-2010, 10:01 AM   #12 (permalink)
Pilot-Matt's Avatar
It'll fit
The plate fits through the rim, just tip the plate on-end and feed it through the rims center hub then the cable.
