Has anyone put in a full size spare in an '09 Pilot (Touring if it matters)? I've seen posts for the '03 - '08 pilots, but nothing for the '09. TIA
#2 (permalink) | |
The Pilot has been exceptional in comfort, performance and handling.
#3 (permalink) | |
Do you worry about the finish of the alloy wheel getting screwed up under the car? |
2009 DCP Touring, Navi & RES 2004 Acura TSX (bunch of mods b/c its fun) 2008 Ducati 1098 R.I.P. |
Just to clarify, the wheel face is facing down, correct? I wonder if there is a wheel cover that might fit over, yet not create too much drag. Can you post a picture as to what a full size looks like up in there?
#9 (permalink) | |
Full size spare (steel wheel) vs compact
Funny, I guess the guy has more than one b/c I just bought one from the same guy. YEAH!!
#11 (permalink) | |
#12 (permalink) | |
#13 (permalink) | |
#14 (permalink) | |
First off, I've heard of stories (yeah, I know, grain of salt) that contribute differential wear to tire tread depth differences. Point being, most SUV tires get replaced out of age and not wear, so why rotate a tire in. My goal is to provide a full size spare when needed, then to get the flat fixed. If it is a side wall issue, well, then I've got a case to slide a new tire of the same type (i.e. getting the Michelin) and the opposite tire of the flat becomes the spare. Either way, the spare stays a spare until the flat is non-repairable or an entire axle set needs replace or the whole set needs to be replaced.
#15 (permalink) | |
I guess it depends on how long you intend to keep the Pilot. A full size spare used occasionially would allow you to buy three tires ("assuming" that brand/pattern still exists)-saving an old one as a spare and rotating the "old" spare into the mix. I plan on using a 5 tire rotation because I trade/resell at 5 years/60-75K intervals and might as well use the extra 20% total treadlife (w/ 5 tire use)rather than trade it away unused. At that point I'll put the donut back on and sell the OEM alloy rim on e-bay or in the HP-org classifieds. YMMV
