I was surprised to find that this forum didn't have a suspension/chassis/brake area. (?) This doesn't necessarily fall under "performance."
Anyways, there's a few 2" lift kits for the Ridgeline. Has anyone considered putting one on a Pilot. The only complication I could see would be the fabrication/shortening of new front sway-bar links. Basically it's not quite a body lift and not quite a suspension lift. It's 4 2" spacers for the struts, but it looks nice and allows for slightly larger tires. http://www.ridgelineownersclub.com/f...light=lift+kit
'04 Pilot EXL '07 Ridgeline RTS |
Some have considered it, but there are no kits per se for the Pilot. Technically spacer on struts is a suspension lift. From personal experience, spacer lifts will give a harsher ride. Now if someone could make an aftermarket coilover kit, similar to the IconDynamics set for the Pilot, that would be something to consider!
http://www.iconvehicledynamics.org/catalog/ |
#3 (permalink) | |
I do plan on picking up a lift for the Ridge, and I'll happily check our Pilot to see if it looks compatible. I'm simply surprised that I would be the first to propose this with a platform that is over 6 years old. I won't be putting a lift on our Pilot because, well, it's my wife's.
The ridge line and 2009 share suspension, but it is NOT the same as the 2003-2008 design.
This is not to say that a spacer cannot be fabricated for the coil spring, or a longer spring custom-ordered from and off-road suspension shop. The roughly 1" longer shock should be very easy to find.
#9 (permalink) | |
06 Pilot Ex 4WD (RIP Old Friend) 08 Acura MDX New Family Truckster - Wifes 2011 Tacoma 4x4 Double Cab TRD Off-Road - Mine |
reviving an old thread, I know!
I originally looked into getting a lift for the pilot, then got a jeep wrangler. having researched ALOT about lifts and how different lifts affect steering geometry, I can honestly say its not worth (to me anyway) putting in a 2" puck type lift for a slightly larger tire (for the sake of look - definitely would degrade on road handling - and still unsuitable for offroad use). I even considered a 245.70.16 tire (orig is 235) to fill the wheel well - but ultimately decided against it. Sent from my Autoguide iPhone app |
