Nitrogen Tire Fill - Honda Pilot - Honda Pilot Forums
Old 10-02-2008, 12:41 PM   #1 (permalink)
tangotango99's Avatar
Question Nitrogen Tire Fill
Nitrogen Filled Tires, will it really help improve your MPG or is it another snake oil product.
Old 10-02-2008, 12:43 PM   #2 (permalink)
Default Re: Nitrogen Tire Fill
Guess!
It does not help MPG.
Old 10-02-2008, 12:55 PM   #3 (permalink)
Default Re: Re: Nitrogen Tire Fill
Originally posted by N_Jay
Guess!
I just recieve and ad. from my local Honda dealer for $9.99($10.00) they will fill my tires with mpg friendly nitro.
Old 10-02-2008, 01:00 PM   #4 (permalink)
Default Re: Re: Re: Nitrogen Tire Fill
Well at least they are not using mpg unfriendly nitro.
Old 10-02-2008, 01:08 PM   #5 (permalink)
jay_man2's Avatar
You'll get better mileage on the way home after the nitrogen fill, since you'll be toting a lighter wallet home.
Go Hoos!
jay_man2 is offline   Reply With Quote
Old 10-02-2008, 01:29 PM   #6 (permalink)
Default Re: Re: Re: Re: Nitrogen Tire Fill
Now "snake oil" from a reputable dealer,next they will be selling turbinate also.
Old 10-02-2008, 02:36 PM   #7 (permalink)
Jose San Juan
Josey92's Avatar
Send a message via AIM to Josey92
FWIW, I believe the thought behind the mileage argument/"sell" is that nirtogen is not/less susceptible to changes in temperature, thereby keeping consistent prescribed pressure in your tires and avoiding fluctuation in rolling resistance caused by the change of temperature.
Should you have a slow leak though, good luck in finding a place that has nitrogen to fill the tire. Introducing regular compressed air completely negates the whole idea of having nitrogen.
Keep in mind this is coming from someone that has bought the snake oil.
2009 MB GL450 ("The Oven" -- yup , the girls again) <br>
* 2006 EX-L Nighthawk Black Pearl
<b>"Suzie"</b> (as named by my daughters) [ended lease]
* 2003 Silver Pilot EX-L [ended lease]
Josey92 is offline   Reply With Quote
Old 10-02-2008, 02:48 PM   #8 (permalink)
Regular air is 75% nitrogen anyway.
Old 10-02-2008, 03:01 PM   #9 (permalink)
The real issue is dry gas vs. moist air.
Yes dry gas is "better", and nitrogen is a dry gas.
But is it better in any meaningful way? Probably not for the average driver.
Old 10-03-2008, 04:55 PM   #10 (permalink)
SNAKE OIL.
Air is 78% nitrogen. Only fill your tires on a cool dry day. Be sure to leave out the Oxygen.
mikesrc is offline   Reply With Quote
Old 10-08-2008, 10:58 AM   #11 (permalink)
Send a message via AIM to truck11
Not worth the $10 ....
My understanding on Nitrogen is that it does not leak out through the rubber as regualr 'air' does - so in effect, you maintain proper tire pressure longer.
Still not worth $10. Just check and maintain your tire pressures regularly and their is your MPG savings.
_____
'11 Jeep Grand Cherokee Limited - V8 4wd
'07 Pilot EXL awd (sold)
'06 DRZ400e
'05 FX-35 awd
'02 Taos pop-up camper
truck11 is offline   Reply With Quote
