It's amazing!!! - Honda Pilot - Honda Pilot Forums
Old 02-23-2003, 04:53 PM   #1 (permalink)
but still kickin'
Older than dirt's Avatar
Send a message via AIM to Older than dirt
Default It's amazing!!!
Can you determine how this works??? Betcha can't...
The Flash Mind Reader
2003 Honda Pilot Taffeta White EX-L RES Air Deflector, Fog Lights, Rear Splash Guards, Rear Back-Up Sensors, Auto Day/Night Mirror, all interior wood grain options, Separation Net, WeatherTech® Advantage Carpet Mats, WeatherTech® Cargo Liner, AutoShade Ventvisor® Wind Deflectors and 70 MPH vibration!!!
Older than dirt is offline   Reply With Quote
Old 02-23-2003, 06:40 PM   #2 (permalink)
tibbitts's Avatar
Default Pretty Cool
Yes and No, Actually, my sixteen year old math whiz figured it out in one try. As soon as he showed it to me, it was "Duhhhhhhhhhh!" Still pretty cool, nonetheless.
'03 Honda Pilot EXL-RES Havasu Blue #20,620
Cross bars, Splash guards, Running Boards, Hitch on the way
tibbitts is offline   Reply With Quote
Old 02-23-2003, 06:40 PM   #3 (permalink)
erpeters's Avatar
Every possible value that you could reach has the same symbol each time. It is a bit confusing becasue the "chosen" symbol is generated randomly.
erpeters is offline   Reply With Quote
Old 02-23-2003, 06:45 PM   #4 (permalink)
Twinkie's Avatar
Every 9th digit has the same value (0,9,18,27,36, etc.). These are the only possible numbers that you can reach using the formula provided.
'03 Nighthawk Black Pearl EX-L #26,097
Side steps, Chrome Bumper Garnish, Rear Splashguards, FormFit Air Deflector, Cargo Tray, Center Console Foam Pads, New Lower Friction Door Seals (ah, sweet silence)
Twinkie is offline   Reply With Quote
Old 02-23-2003, 08:12 PM   #5 (permalink)
but still kickin'
An old parlor trick called "casting out nines" where all the symbols shown for any two digits adding to nine have the same symbol - cleverly, the symbol changes every time so it's harder to track. Note that all the symbols where the digits sum to 9 are identical before you click on the crystal ball.
Subtracting the sum of (a+b) from a number ab gives you two digits that add to nine since:
ab - (a+b)) = 10a + b - (a+b) = 10a - a + b - b = 9a
since a can only be an integer in the decimal system , the answer 9a is always a multiple of the integer 9
since the original number has two digits, a>0
the only possible sets of numbers that can meet this criteria are
1 X 9 = 09
2 X 9 = 18
3 X 9 = 27
4 X 9 = 36
5 X 9 =45
6 X 9 = 54
7 X 0 = 63
8 X 9 = 72
9 X 9 =81
Probably more than you ever wanted to know...
Old 03-21-2003, 05:57 PM   #6 (permalink)
Le Moderator™ Ranger®
kemosabe's Avatar
1. Focus on the dot in the center.
2. Then move your head forward and backwards to/from the monitor screen.
3. Weird, huh???
Old 03-21-2003, 06:07 PM   #7 (permalink)
kemosabe's Avatar
Default Eye Examination Chart
Increase your distance from the chart until it is readable.....
