![]() ![]() Join Date: Jul 2002
Most of you are probably looking at the image and saying ,huh???????? as I did at first.
The two squares are in fact the same shade. Try this: This description is rather long but in essence, you are moving squares A and B next to each other for the sake of a side by side comparison. Print two copies of the image. Take one copy and fold it back or cut it off so that the fold or cut runs about 1/2 way across square B. Overlay the folded/cut copy over the first copy so that the images are aligned. Notice the 2 B squares are the same shade. (They should be because these are identical copies.) Now move the folded/cut copy so that the 1/2 B square overlays the A square on the first copy. Note that the A and B squares are in fact the same shade. This can also be done in a photo publishing software so you could sample one of the squares and compare it to the other. |
That is amazing! I didn't believe it so I used paintshop pro to cut out "B" and place it over "A". An Exact Match. Truly amazing NHPilot.
TKO ![]() Sandstone Metalic LX #21323 An Arizona Piloteer |
