Hi guys,
Thought I'd break in this topic with a mind bending puzzle. This is an engineering drafting problem. 3D rendition in 2D. Lines which are invisible or inside a structure are dashed. Lines that are visible are solid. You have the front, side and top view. Here is an example:
'03 SS Pilot EX-L RES X-Bars, RBs & MGs #21991 |
In the example above, the top view has a dashed line to represent the angle underneath the structure. Now here is the mind bender. In your solution, keep in mind the dashes and solid lines. There are no errors in the two views presented. Find the top view. A verbal description will do.
Good luck!
#3 (permalink) | |
Super Duper Member
However, looking exclusively at the image of the front structure, it implies that there is either a rectangular depression or a protrusion that is smaller than the face it is on. For the Side View to be consistent with the Front View, it should just be a rectangle with three dashed lines representing the depression or for the Front View to be consistent with the Side View, it should have two thin retangles at the top and the bottom and a bigger rectangle in the middle. What am I missing here? Obviously, my feeble brain isn't able to understanding something. |
Everyone thinks of a rectangle when trying to figure it out. Makes sense to deduce that from the "squarish" front and side views. Good going! Lemme look at yours. - Ben
![]() Educate me!!! - Ben
#14 (permalink) | |
![]() - Ben Computer Network Engineer - Nerd Extraordinaire
#15 (permalink) |
![]() ![]() Join Date: Jul 2002
Thanks, I'm a mechanical design engineer. I use a CAD software called SolidWorks. If you take a look at some of the images in the gallery at solidworks.com/swdocs/solidIndustrysol, you'll quickly see that these simple drafting exercises were no great feat.
Rich |
