Help With Low Cylinder Compression - Honda Pilot - Honda Pilot Forums
Old 07-21-2009, 10:18 AM   #1 (permalink)
Wolfman_matt's Avatar
Unhappy Help With Low Cylinder Compression 95 Accord
Guys - while my wife gets the pilot, my DD is a 95 accord with 225k on the clock. It sometimes runs a little rough but generally OK and now needs some AC work. Before sinking a lot of $ in it I checked the compression.
While consistent between cylinders it is very low across the board (95-110 psi). Haynes manual for this engine specifies
Std 178 psi
Min 135 psi
Max variation between cylinders 28psi
Can I continue to drive for an extended time at such a low compression or do I have a time bomb?
Matt
Sagebrush Pilot EX
I-VES DVD
fog lights
MDX Wheels
Chrome side steps
chrome grill and handles
Yakima Rack
Woodgrain steering wheel
Wolfman_matt is offline   Reply With Quote
Old 07-21-2009, 10:27 AM   #2 (permalink)
Are you sure your gauge is reading correctly?
Any other symptoms?
Old 07-21-2009, 10:46 AM   #3 (permalink)
N_Jay - I would assume that the data is good (maybe I shouldn't) as it was done at my neighbors repair shop. They did check each cylinder twice.
The car is low on power but I can't remember it ever having much. The MPG has always seemed low to me for such a small engine (26-30). I also notice under hard accelleration that there sounds like a loud air leak coming from the engine compartment. Overall it seems to idle and drive like I would expect a high mileage vehicle to.
Matt
Sagebrush Pilot EX
I-VES DVD
fog lights
MDX Wheels
Chrome side steps
Yakima Rack
