question about diesel fuel... - Honda Pilot - Honda Pilot Forums
Old 06-24-2008, 04:48 PM   #1 (permalink)
rlapid's Avatar
Default question about diesel fuel...
with gas prices continuing to rise, i've been looking into diesel. i'm not too familiar with diesel fuel, as i've never owned a diesel vehicle before, so bear with me. i noticed that 'top tier' or 'premium' gas stations like chevron charge more for their diesel fuel than discount gas stations, just like they do with unleaded fuel. are additives like techron or v-power added to their diesel which makes it superior? or is all diesel the same?
Old 06-24-2008, 05:18 PM   #2 (permalink)
Are there any diesels currently on the market that meet CA-state emissions?
That being said, are the vehicles you're looking at get sufficiently improved gas mileage over the Pilot to offset the higher price of diesel?
Does it make financial sense to trade-in your Pilot to get a new vehicle that gets better gas mileage? In many cases, it doesn't, but I wasn't sure if you thought about it.
1995 Yamaha FZR600
Old 06-24-2008, 05:34 PM   #3 (permalink)
By the end of 2008 we'll see 50 state approved diesels from Mercedes and VW. VW expects to deliver their first vehicles before the end of summer.
Honda early to mid next year. Subaru and Nissan will follow. Wierdly no work from Toyota except in their Tundra/ Sequoia.
Ford despite having great diesels in Euro Silence. Ditto GM. Chrysler sells several of its vehicles with diesels MB or VW engines. this will probably continue
Old 06-24-2008, 09:08 PM   #4 (permalink)
macphanatic's Avatar
I can't speak regarding the new low sulfur diesel fuel or that which is sold on the West Coast. However, the guys that run diesels in my area of PA tend to use Sunoco diesel in the colder months as it has a lower parafin content, thus it jells at a lower temperature. They are less picky during the warmer months.
Old 06-24-2008, 11:51 PM   #5 (permalink)
typically a diesel vehicle will get 30 -40% better mileage than a gas vehicle. So a 20mpg pilot would get between 24 and 28 mpg. Diesel is at a 25% premium. It is still more cost effective to drive a diesel as compared to a gasoline model in most instances, but it is approaching the point where it isn't. Now diesel engines are typically built more robustly just due to the nature of their ignition by compression (they have to be built heavier usually), BUT with all the emissions stuff, they cost more than a gasoline engined car, so.....
a year ago, I would have beat a door to a honda dealer for a near 30mpg diesel pilot, even at a 3 to 4K premium
Now, I just don't know..
2007 EXL RES 4wd - Aberdeen Green (awesome color)
<div><p><img src="http://i46.photobucket.com/albums/f120/Konechiwa/john_c__reilly10.jpg" hspace="5"></p></div>
tfrain is offline   Reply With Quote
Old 06-25-2008, 01:34 AM   #6 (permalink)
rlapid's Avatar
[i]a year ago, I would have beat a door to a honda dealer for a near 30mpg diesel pilot, even at a 3 to 4K premium
Now, I just don't know.. [/B]
same here. a diesel pilot (or any car for that matter) would be great alternatives to hybrids and E85...
Old 06-25-2008, 02:51 AM   #7 (permalink)
Only one person so far has come remotely close to addressing the OP's original question; the rest have spun off into the tangent on whether diesel is cost effective which wasn't the question. You guys should get into politics.
I have no hard info about the quality differences between brands of diesel, but I suspect it is like gasoline - there are some differences, but in most cases, they're VERY minor.
Old 06-25-2008, 05:36 AM   #8 (permalink)
You are correct in your assumptions. Alot of car diesel owners add a small of regular gas to each tank of fuel in the winter to keep it from freezing. That is why I was suprised to see the comment about the Sunoco diesel, I did not know they had lowered the part that freezes. I used to have a VW diesel Rabbit back in the early 80's and it was great, obviously not the low sulphur available now, so it smoked when the gas pedal was floored and the engine was powering up a long hill or whatever. Upshifting would have stopped the smoke but also gotten it out of the power range and the vehicle would have slowed down. On diesel vehicles there is also a water filter that must be drained periodically, as in every oil change is fine in most cases. During the winter you need to do it more often. The regular gasolline just made it a tiny bit thinner so it didn't freeze when the temp got cold. I live near DC and yes it froze up on me several times!
mikey159 is offline   Reply With Quote
Old 06-25-2008, 10:27 AM   #9 (permalink)
Olde Timer Administrator
colorider's Avatar
Moved to Off-Topic
'10 Honda Pilot EX-L
'11 Ford Mustang GT/CS
'12 Yamaha XT1200Z
Enjoy Life Today
Yesterday Is Gone
Tomorrow May Never Come
Old 06-25-2008, 10:52 AM   #10 (permalink)
Agreed. Until the new 50-state diesels start coming out, it's hard to say if they'll be as fuel efficient as their "smoggy" predecessors and if they'll be reliable (new emissions components).
Like hybrids, it'll be easy to determine the premium for getting diesel on models that offer both a diesel and gas engine option and figure out if it makes financial sense to buy one (i.e. increased gas mileage offsets the increased price of diesel).
1995 Yamaha FZR600
Old 06-25-2008, 01:59 PM   #11 (permalink)
Quite right, we did not answer the specific question. However, the poster said he didn't know a lot about diesels and to bear with him. Seeing as how I don't have any info about the differences in diesel fuels, but I do have some info on the merits of diesel powered vehicles, I thought I would throw a comment out there in order to share some info so he might know a little more about them. But thanks for making the point - else his question might not have been answered!!
Old 06-25-2008, 08:40 PM   #12 (permalink)
rlapid's Avatar
thanks everyone for the replies! yes, the thread did drift a little, but as a result, i learned more about diesel and diesel-powered vehicles. hopefully diesel has a promising future here in the US...
Old 07-10-2008, 07:26 PM   #13 (permalink)
For me, I want to have a hybrid diesel engine. But the cost of buying one is just the same like using a diesel engine. Diesel still the best gasosline to use since it is more cheaper than unleaded gasoline.
______________
A must look: Autopartswarehouse
KarenCaren is offline   Reply With Quote
Old 07-10-2008, 07:58 PM   #14 (permalink)
rlapid's Avatar
A hybrid diesel engine? sounds interesting. I don't think i've ever seen any cars that use one. here in CA, diesel costs quite a bit more than even premium unleaded. however, you can still save quite a bit of money driving a diesel car. i really hope honda releases their i-ctd over here...
Old 07-10-2008, 11:45 PM   #15 (permalink)
iivtecracerii's Avatar
they wont. i-CTDi is old news.
we'll be getting the new i-DTEC clean diesel engines.
