![]() ![]() ![]() ![]() ![]() Join Date: May 2003
Can't get a screw to budge to reupholster the front
seats on my old '93 Miata. Tried Liquid Wrench, PB Blaster, & Kroil. No luck.Should I go buy a small torch from Home Depot? Advice on how to use it properly for this function? Any other bright ideas? TIA! Free beer and pizza for anyone who can come by and help before I burn down the house!
Thanks, Robrecht! Charcoalishlygreenishbluishyrealpink&tealfleck metallic EXL-RES with Rumble Seat, Foglights, Chrome Bumper Garnish (of course!), and Merrywang Transport Netting. And an RX-8 or Miata for my twice daily hill climb. |
If you don't have one, get a heat gun. A lot easier to control the heat than a torch.
You're on the right track - penetrant, heat, tapping, etc. And patience. Time is on your side. But there are some that are just not going to budge and you have to whack/drill whatever. - Mark |
#3 (permalink) | |
Drill Here, Drill Now
That screw looks pretty accessable. I'd hit it with the hottest soldering iron you can get your hands on then use this tool:
http://www.sears.com/sr/javasr/produ...seBVCookie=Yes |
It's hard to tell from the picture but are you using a #2 phillips with a grip you can really get some leverage with? Be careful with an impact driver. How firm is whatever the screw goes into? It needs to be pretty firm if you use an impact driver.
I'd start by taking a hammer to the end of the screwdriver and seeing if the impacts loosen anything.
I'd also get the sears "screwed up screw remover" as well as this project is going in that direction....
Olde Timer Administrator
As always - make sure you have the right size Phillips (#2 typically). Maintain steady constant torque on the handle and tap the handle of the screwdriver with a hammer. Sometimes even changing direction (as in tightening) and then trying to loosen will help. I've had screws seize like this on motorcycles, particularly when threading into an alloy part (the use anti-seize paste on the threads at assembly helps reduce this risk).
You might also try gripping the screwdriver with all you have and with steady pressure towards the screw give the handle a VERY solid twist. As for the pizza and beer offer. if I wasn't snowed in, I would be there in a flash!! Good Luck!!!
'10 Honda Pilot EX-L '11 Ford Mustang GT/CS '12 Yamaha XT1200Z Enjoy Life Today Yesterday Is Gone Tomorrow May Never Come |
#13 (permalink) | |
#14 (permalink) | |
#15 (permalink) |
