Does anyone have any experience or suggestions for protecting electronics (i.e., circuit board and ribbon cable) from corrosion?
The components are part of the power supply for my pool equipment. Now you would think this hardware was designed for outdoor use, but I've gone through 4 boards in about 2 years. Fortunately, the parts are still being replaced under warranty. I've talked to the manufacturer and they sent an "improved" version that they claim will fix the problem, but comparing the parts side-by-side, they look identical. I was expecting to see better shielding or protection on the electronics. The board itself is not the problem, but there is a metal foil ribbon cable connecting the board to the power supply and it keeps corroding right where it comes through the housing. I've got about one more free repair before I have to start paying for labor. I may try to do a complete return and switch to a different product, but in case I can't I'd like to have a back up plan for long term protection. I'm hoping that I find something that will protect the "weak link" in the ribbon cable. People have suggested clear Krylon and I've found some spray on coatings that claim to be for electronics. However, I haven't seen anything completely convincing (websites seem to be flaky or I find complaints on other message boards about the products). I'll post a picture as soon as I locate the ones I took. The problem part is not anything I can heat shrink or enclose, so I was hoping there is a spary material that is know to work for this application. Please let me know if you have any product names or websites you can point to. Thanks!
#2 (permalink) | |
Where does the ribbon cable go?
Can these be mounted in a weather-tight electrical cabinet? If so, that should solve most of your problem.
Is the ribbon cable exposed to sunlight? Is it rated for UV exposure? If not, that may be your problem and coating it with a material that is should work. I wouldn't use anything clear though.
Drill Here, Drill Now
The control panel is a membrane keypad. The ribbon cable connects the membrane keypad to the electronics inside the control panel. (I mis-stated before.)
I could possibly seperate the control panel cabinet from the top half (power supply) and only put the electronics into a watertight enclosure. But this would require more extensive modifications. There is also a heat sink on the back of the box for the control panel.
Site Sponsor
There is something that would work in this case
![]() There was a process called "tropicalizing", that started back in the early '40s (or perhaps before) for use on electronic equipment in the tropics, making it impervious to heat and moisture that would damage the primitive circuitry. It's still used in many electronic applications on oceangoing vessels, and as I recall is a very light spray-on coating. Might be worth some Googling
![]() www.oemacuraparts.com Remember to visit www.hondacuraplanet.com for your accessories needs! See our Pilot monthly special here! http://www.hondacuraplanet.com/mm5/m...tegory_Code=SP |
