XM antenna outside? - Honda Pilot - Honda Pilot Forums
Old 01-02-2006, 11:41 AM   #1 (permalink)
wstromer's Avatar
Default XM antenna outside?
Because of poor signal inside the house I have had to place my antenna outside. The docs on this thing don't indicate if this thing is weather-proof or not. Has anyone had to do this with the home antenna?
wstromer is offline   Reply With Quote
Old 01-02-2006, 12:16 PM   #2 (permalink)
jl_ss's Avatar
Default Re: XM antenna outside?
The documentation included with my Delphi SKYFi2 indicates that the antenna included in the home kit is an indoor/outdoor antenna. I only have one 2" square spot in my house that I get reception due to a large hill behind our house. So I use the home antenna in this spot and repeater antennas at the two stereo locations in other places within the house.
Old 01-02-2006, 12:38 PM   #3 (permalink)
wstromer's Avatar
I've got a metal foil coating on the underside of my roof sheathing that's 100% effective at signal blocking (but good for cutting AC costs).
I have the Delphi roadyXT with the home kit. I bet it's the same antenna.
Thanks for the response. Worst case I suppose would be I replace it after a few months.
Old 01-02-2006, 03:02 PM   #4 (permalink)
jl_ss's Avatar
I believe Delphi uses the same antenna across the entire line of receivers.
