Using a laptop without the boss knowing - Honda Pilot - Honda Pilot Forums
Old 08-30-2005, 06:07 PM   #1 (permalink)
Ex-Pilot Owner
FLPilot's Avatar
Default Using a laptop without the boss knowing
Okay, I have a question that I am sure someone here might know. Say you are given a laptop from work. The laptop has cellular connectivity which blocks out websites due to it going through the main server at work. The question I have is, if I add an external hard drive, can I install a browser on it and use the laptop with my own network card to surf the net either at home or out and about where wireless connectivity is offered and not have any traces of that left on the internal hard drive? (trying to catch my breath)
Old 08-30-2005, 06:29 PM   #2 (permalink)
CMasten's Avatar
Default Re: Using a laptop without the boss knowing
anything you do can be tracked, but it depends on the level of expertese of the person tracking. I would say if you use your wireless nic, connect to a WAN in your area and just blow away the history and recent web sites etc, you should be ok. If your IT group or boss is pretty tech savy they can track this more throughly. There are other areas that track system wide changes like the event viewer etc that you would need to think about. There are some pretty inexpensive laptops out there now (used on Ebay etc) that might be less hassle.
Old 08-30-2005, 07:31 PM   #3 (permalink)
ictvuser's Avatar
Disclaimer: Standard warnings apply - use at your own risk!
There are a few ways you can do this but it depends on what OS you are using and which browser.
If you are using a Windows based OS and Internet Explorer, the following will give you some guidelines on what to do.
One option is to use a tool like McAfee's Shredder to remove the user profile you were using. The profile usually resides under C:\Documents and Settings
Another option is to move the profile for your user to the new drive.
1) As Admin, create a folder "Documents and Settings" on the new drive and assign Everyone access to it (e.g., right click on the folder, select the Security tab, and add the group Everyone w/full access.
2) As Admin, create a non-admin user
3) Login as that user
4) Login as admin
5) Locate the new user's profile
See http://support.microsoft.com/default...b;en-us;214470
[URL]http://windowsxp.mvps.org/userpath.htm[\URL]
Run regedit and go to the ProfilesList key and find the ProfileImagePath associated with the new user. Look for the username is at the end of the path. The path usually looks like "%SystemDrive%\Documents and Settings\<user>".
6) Replace the %SystemDrive% to the new drive.
"X:\Documents and Settings\<user>"
7) Login as that user and verify that the profile now resides on the new drive.
8) Login as admin and remove the old user profile ("C:\Documents and Settings\<user>". If a file is locked or in use, just reboot the computer and repeat.
Another option is create a RAM disk/drive (depends on which OS you are using).
Honda Pilot 2004 EX-L SBP
Old 08-30-2005, 07:47 PM   #4 (permalink)
jl_ss's Avatar
You could boot from a live linux CD like knoppix using your own network card.
Old 08-30-2005, 08:03 PM   #5 (permalink)
robrecht's Avatar
White collar crime ...?
Thanks, Robrecht!
Old 08-30-2005, 08:13 PM   #6 (permalink)
f2benny's Avatar
just bring your own wireless equipped laptop in and glom onto a wireless connection from the area if one's available
f2benny is offline   Reply With Quote
Old 08-31-2005, 09:16 AM   #7 (permalink)
'da Moderator
ramirami's Avatar
oxymoron
2003 Starlight Silver EXL_RES
2011 Black Audi Q5 2.0T
Old 08-31-2005, 11:36 AM   #8 (permalink)
robrecht's Avatar
Originally posted by ramirami
oxymoron
OxyContin
Thanks, Robrecht!
Old 08-31-2005, 12:59 PM   #9 (permalink)
krygny's Avatar
FLPilot is a police ocifer. That would make it a BLUE collar crime.
(AH HAR HAR HAR!! Sometimes, I just kill me.)
2003 EX-L, Sage Brush Pearl
Old 08-31-2005, 01:22 PM   #10 (permalink)
Ex-Pilot Owner
FLPilot's Avatar
I thank everyone for their replies. The IT person is a control freak and I have no clue what programs they may have that watches what we do on the laptops. I just thought if I had an external drive and installed fire fox on it, that all or at least most of the traces would stay on the external drive. I guess it was more of a hope that actually thinking it might work. I figured the operating system would record what I did like coming to hp.org while on duty. Oh well, guess it's better I don't try to cut corners. BTW, the main reason I was trying to do this is because our server is made to block all internet sites, but allow intranet to pass.
Again I thank you all for the info provided.
Old 08-31-2005, 05:49 PM   #11 (permalink)
robrecht's Avatar
I actually thought of that too but figured I was already in enough trouble with the law!
Thanks, Robrecht!
Old 08-31-2005, 06:14 PM   #12 (permalink)
MPSpecter's Avatar
check www.slickdeals.net , they always have coupon from dell for 40% off and some are stackable....
NBP No. 21712
MPSpecter is offline   Reply With Quote
Old 08-31-2005, 06:49 PM   #13 (permalink)
Ex-Pilot Owner
FLPilot's Avatar
You guys are too much.
Old 10-12-2005, 07:32 PM   #14 (permalink)
robrecht's Avatar
Default Stealth Surfer USB Flash Drive
This is a product that caters to the extremely paranoid, but nevertheless it is a pretty damn good idea. This USB flash drive comes loaded with everything you need to prevent the man from catching you hax teh Gibson or maybe prevent your boss from discovering your fetishes.
StealthSurfer is a Windows PC compatible key-sized USB device that is preloaded with Firefox, Anonymizer, RoboForm, and Thunderbird software configured and integrated for optimum privacy. When using StealthSurfer, all your sensitive Internet files such as cookies, history, and cache are stored on the StealthSurfer device instead of your computer.
Thanks, Robrecht!
Old 10-14-2005, 02:54 AM   #15 (permalink)
Ex-Pilot Owner
FLPilot's Avatar
Thanks robrecht, but I just assume not to bother with this project any longer. When it comes down to it, the equipment isn't mine and I really shouldn't be online while at work anyway. Although the graveyard shift gets boring about 4am when not a sole is out and about. I thank you for all the suggestions though.
