UPDATE (August 12, 2010): Thanks to member, "soopermoto" we now have access to the TSB's and SNA's! Here's my original posting with updated URL's.
After a bit of playing around I've found the URL pattern to get all Technical Service Bulletins (TSB) and ServiceNews Articles (SNA) from Honda. Unfortunately I don't know how to find an index. If you're looking for a particular TSB or SNA and don't have the TSB number or SNA publication date you'll need to just look for them sequentially. To find a TSB The URL pattern is: http://techinfo.honda.com/Rjanisis/pubs/SB/AYY-XXX.PDF Where YY is the two-digit year and XXX is the 3 digit sequence number. For example, the Service Bulletin for "Navigation System DVD Information and Inspection" (bulletin number 05-032) can be found here: http://techinfo.honda.com/Rjanisis/pubs/SB/A05-032.PDF NOTE: Change the "A" to "B" and you'll find the TSBs for Acuras! To find a SNA The URL pattern is: http://techinfo.honda.com/Rjanisis/pubs/SN/AYYMM00.PDF Where YYMM is the two-digit year and two-digit month of the article. They come out once a month. For example, to get the July 2010 ServiceNews Article the URL would be: http://techinfo.honda.com/Rjanisis/pubs/SN/A100700.PDF And, you can change the "A" to "B" to get the Acura ServiceNews Articles too! Maybe someone would like to go through them and post an index? Now that would take a good chunk of time! Have fun! Larry.
'06 EX-L Nav 2WD (Redrock Pearl) Stop Identity Theft in 10 Minutes! DiskStroyer: http://www.diskstroyer.com |
Using the link above, I searched through all of the SBs and generated a consolidated list. Below are the SBs published in 2010 that affect Pilot owners. For owners of other Honda vehicles, the attached .pdf lists all SBs from 2010.
--------------------------------------------------------- 10-002 (February 23, 2010) Photos For Warranty Paint Repair Claims Applies To: ALL http://techinfo.honda.com/Rjanisis/pubs/SB/A10-002.PDF 10-004 (July 27, 2010) Moonroof Does Not Open Applies To: 2009–11 Pilot – See VEHICLES AFFECTED http://techinfo.honda.com/Rjanisis/pubs/SB/A10-004.PDF 10-005 (January 22, 2010) Left Third Row Seat-Back Cover Is Broken or Loose Applies To: 2009 Pilot – ALL 2010 Pilot 2WD – From VIN 5FNYF3...AB000001 thru 5FNYF3...AB014210 2010 Pilot 4WD – From VIN 5FNYF4...AB000001 thru 5FNYF4...AB024655 http://techinfo.honda.com/Rjanisis/pubs/SB/A10-005.PDF 10-009 (March 1, 2010) 2011 Pilot: PDI and New Model Information Applies To: 2011 Pilot – ALL http://techinfo.honda.com/Rjanisis/pubs/SB/A10-009.PDF 10-011 (March 5, 2010) Service Manual Update: Power Window Goes Up and Reverses On Its Own, Is Slow to Open and Close, or Squeals, Creaks, Clunks, or Clicks Applies To: 2003–10 Accord – ALL 2006–10 Civic – ALL 2007–10 Civic Hybrid – ALL 2007–10 CR-V – ALL 2003–10 Element – ALL 2009–10 Fit – ALL 2010 Insight – ALL 2005–10 Odyssey – ALL 2009–10 Pilot – ALL 2006–10 Ridgeline – ALL http://techinfo.honda.com/Rjanisis/pubs/SB/A10-011.PDF 10-013 (March 12, 2010) Rear Suspension Crunches or Squeaks Over Large Bumps Applies To: 2009 Pilot 2WD – From VIN 5FNYF38..9B000001 thru 5FNYF38..9B028116 2009 Pilot 4WD – From VIN 5FNYF48..9B000001 thru 5FNYF48..9B055709 http://techinfo.honda.com/Rjanisis/pubs/SB/A10-013.PDF 10-018 (April 6, 2010) Headliner Rattles Applies To: 2009 Pilot EXL, EXL-R, Touring – ALL 2010 Pilot EXL, EXL-R, Touring 2WD – See VEHICLES AFFECTED 2010 Pilot EXL, EXL-R, Touring 4WD – See VEHICLES AFFECTED http://techinfo.honda.com/Rjanisis/pubs/SB/A10-018.PDF 10-021 (May 20, 2010) Cargo Floor Box Lid Latch Binds or Does Not Open Applies To: 2009 Pilot – ALL http://techinfo.honda.com/Rjanisis/pubs/SB/A10-021.PDF 10-029 (June 25, 2010) Vehicle Pulls/Drifts Right or Pulls Right While Accelerating Applies To: 2009 Pilot – ALL 2010 Pilot 2WD – From VIN 5FNYF3...AB000001 thru 5FNYF3...AB015647 2010 Pilot 4WD – From VIN 5FNYF4...AB000001 thru 5FNYF4...AB023050 http://techinfo.honda.com/Rjanisis/pubs/SB/A10-029.PDF 10-030 (July 27, 2010) Product Update: Parasitic Current Draw From Moonroof Control Unit Can Discharge the Battery 2009 Pilot 2WD – From VIN 5FNYF3...9B001009 thru 5FNYF3...9B028589 2009 Pilot 4WD – From VIN 5FNYF4...9B002044 thru 5FNYF4...9B055918 2010 Pilot 2WD – From VIN 5FNYF3...AB001826 thru 5FNYF3...AB023531 2010 Pilot 4WD – From VIN 5FNYF4...AB001756 thru 5FNYF4...AB041284 2011 Pilot 2WD – From VIN 5FNYF3...BB001002 thru 5FNYF3...BB008764 2011 Pilot 4WD – From VIN 5FNYF4...BB001003 thru 5FNYF4...BB015339 http://techinfo.honda.com/Rjanisis/pubs/SB/A10-030.PDF 10-041 (August 12, 2010) 2011 Honda Paint Codes Applies To: 2011 Models – ALL http://techinfo.honda.com/Rjanisis/pubs/SB/A10-041.PDF |
Good stuff, larrys & BK Lounge! I'll add the Pilot-related Service Bulletins published in 2006, keeping BK Lounge's format:
06-009 (February 5, 2008; Supercedes 06-009, dated Sept. 21, 2007) Warranty Extension: OPDS Unit or OPDS Sensor Triggers SRS DTC(s) 15-1, 15-2, 15-3 Applies To: 2003 Pilot: ALL with OPDS 2004 Pilot (Canada-Produced) with OPDS: From VIN 2HKYF1…4H500001 thru 2HKYF…4H549091 http://techinfo.honda.com/Rjanisis/pubs/SB/A06-009.PDF 06-023 (May 11, 2006) Gap Between the Moonroof Visor Seal and the Roof Applies To: 2006 Pilot EX – ALL http://techinfo.honda.com/Rjanisis/pubs/SB/A06-023.PDF 06-030 (June 7, 2006) Idle Vibration or Harsh Shifting Applies To: 2003-2004 Pilot – ALL 2005 Pilot – From VIN 5FNYF18…5B000001 thru 5FNYF18…5B038135 2005 Pilot – From VIN 2HKYF18…5H500001 thru 2HKYF18…5H554958 http://techinfo.honda.com/Rjanisis/pubs/SB/A06-030.PDF 06-048 (July 29, 2006) MIL Comes On With DTC P0116 Applies To: 2005-2006 Pilot – ALL http://techinfo.honda.com/Rjanisis/pubs/SB/A06-048.PDF 06-061 (August 25, 2006) XM® Satellite Radio and Audio Accessories Play at the Same Time Applies To: 2006 Pilot – From VIN 2HKYF1…6H000001 thru 2HKYF1…6H535926 2006 Pilot – ALL Alabama-produced (VIN begins with 5FP) http://techinfo.honda.com/Rjanisis/pubs/SB/A06-061.PDF 06-065 (September 2, 2006) 2007 Pilot: PDI Information Applies To: 2007 Pilot – ALL http://techinfo.honda.com/Rjanisis/pubs/SB/A06-065.PDF 06-066 (October 4, 2006; Supercedes 06-066 dated Sept. 9, 2006) Front Suspension Pops or Clunks While Turning Applies To: 2006 Pilot – From VIN 2HKYF1…6H518835 thru 2HKYF1…H6543232 http://techinfo.honda.com/Rjanisis/pubs/SB/A06-066.PDF 06-068 (May 2, 2009; Supercedes 06-068 dated October 4, 2007) Vehicle Pulls or Drifts, and/or Steering Wheel Is Off-Center Applies To: ALL http://techinfo.honda.com/Rjanisis/pubs/SB/A06-068.PDF 06-081 (November 10, 2006) Horn Honks By Itself in Turns or Over BumpsApplies To: 2003-2004 Pilot – ALL http://techinfo.honda.com/Rjanisis/pubs/SB/A06-081.PDF 06-082 (December 15, 2006) Tubeless Tire Repair Information Applies To: ALL http://techinfo.honda.com/Rjanisis/pubs/SB/A06-082.PDF 06-085 (May 9, 2008; Supercedes 06-085 dated January 22, 2008) Warranty Extension: Vehicle Warranty Mileage Applies To: certain models purchased or leased between April 13, 2002 and November 7, 2006. The most effective way to check a vehicle's warranty coverage is by a VIN status inquiry. Also Applies To: 2003-2004 Pilot OPDS Unit and UPDS Sensor (warranty already extended once to 150k miles under Service Bulletin 06-009, now 06-085 extends it to 157,500 miles) http://techinfo.honda.com/Rjanisis/pubs/SB/A06-085.PDF 06-089 (December 8, 2006) 2007 Honda Paint Codes, Exterior and Interior Color Code Locations Applies To: 2007 Models – ALL http://techinfo.honda.com/Rjanisis/pubs/SB/A06-089.PDF 06-092 (December 12, 2008; Supercedes 06-092 dated December 22, 2006) Booming or Humming Noise from Speakers While Driving Applies To: 2006 Pilot 2WD: ALL 2007 Pilot 2WD: EX – ALL; LX: From VIN 5FNYF2…7B000001 thru 5FNYF2…7B006392 2008 Pilot 2WD: EX – From VIN 5FNYF28B000001 thru 5FNYF28B029357 http://techinfo.honda.com/Rjanisis/pubs/SB/A06-092.PDF Hope this is useful... hopefully we can get more years' worth in here soon.
2006 Honda Pilot EX-L 4WD, Sage Brush Pearl 2006 Subaru Legacy SE AWD sedan, Atlantic Blue Pearl Gone but not forgotten, in order of departure: 2006 Subaru Outback 3.0R AWD wagon; 1995 Honda del Sol Si; 1999 Subaru Legacy 30th Anniversary AWD wagon; 2004 Subaru Outback AWD wagon; 1991 Subaru Legacy L sedan; 1983 Honda Accord SE sedan; 1984 Mazda 626 sedan Last edited by keepclam; 08-20-2010 at 08:40 AM. |
Props to the guys above for listing the SBs and SNs released by Honda by year.
Turns out that once you enter the vehicle make, year, and model into this website (Alldata.com), it lists all the SBs and SNs that apply to that particular vehicle. They only provide the title and the YY-XXX code, but that's enough to download the SB/SN directly from honda's website. Here's the website ALLDATAdiy.com :: Access Automotive Technical Service Bulletin and Recall Information |
I have put in the year #s and SB #s for '07, '08, '09, and '10 ... I used it to open 20 at a time...read the heading and then open 20 more.
I hope it useful to others too. If you add to this, please post back. Good luck. BTW, this is a zipped Excel file.
'07 Pilot EX-L w/ Navi |
When I try I get this:
You are not authorized to view the content on this page. If you believe you have received this message in error, please contact the Support Center. Please go back or return to the home page. |
So, until someone learns some username/password we can all share it seems that we're out of luck .Larry.
You can get the SN from my site from 1986 until 2009.
Index of /DIY/ServiceNews on Acuras... but since the MDX and pilot are so similar. |
