How To Post an Excel Table - Honda Pilot - Honda Pilot Forums
Old 03-09-2003, 06:56 PM   #1 (permalink)
Le Moderator™ Ranger®
kemosabe's Avatar
Default How To Post an Excel Table
Background: this is in response to a user who wanted to post their Pilot gas mileage data that they had in a Microsoft Excel spreadsheet into this forum.....
Bring up your spreadsheet in MS Excel. In my case here, I am using Tom Clancy books as my example...
Old 03-09-2003, 06:57 PM   #2 (permalink)
kemosabe's Avatar
Save your spreadsheet as a web page by choosing the File --> Save As... menu option.
I'm calling mine (duh!) clancy.htm
Old 03-09-2003, 06:59 PM   #3 (permalink)
kemosabe's Avatar
Use Wordpad or Notepad to bring up your newly created web page file (in my example, clancy.htm) and search for the line that says "border=0" and change it to read "border=1". Save the change!!
Old 03-09-2003, 07:01 PM   #4 (permalink)
kemosabe's Avatar
Highlight everything starting from the HTML tag that starts with "<"table x:str border=1 until...
Old 03-09-2003, 07:04 PM   #5 (permalink)
kemosabe's Avatar
...the last html table tag near the bottom of the document. Then click on the "Copy" button (or choose the Edit --> Copy menu item).
Old 03-09-2003, 07:06 PM   #6 (permalink)
kemosabe's Avatar
Paste your selected text into your post. Using the keyboard combo of Ctrl-V will work nicely...
Old 03-09-2003, 07:07 PM   #7 (permalink)
kemosabe's Avatar
And when all is said and done, you should have somewhat of a table... (don't know why there is so much space before the table shows up!!! )
1984 The Hunt for Red October
1986 Red Storm Rising
1987 Patriot Games
1988 The Cardinal of the Kremlin
1989 Clear and Present Danger
1991 The Sum of All Fears
1993 Without Remorse
1994 Debt of Honor
1996 Executive Orders
1998 Rainbow Six
2000 The Bear and the Dragon
2002 Red Rabbit
Old 03-09-2003, 07:08 PM   #8 (permalink)
kemosabe's Avatar
Also, be sure that HTML code is turned ON for the thread you're posting to!!!!!
Old 03-09-2003, 07:20 PM   #9 (permalink)
florida_guy's Avatar
Default Screen Capture
Oh mighty graphics master
What do you use to capture your screen shots?
Note: If you want to be sure I see a post either quote a message from me or put - florida_guy - somewhere in the body of the post so it shows up when I search. I am trying to stay active without spending too much time here.
'03 Pilot EX Sandstone Metallic
Options:
Cargo Cover
OEM Hitch
StreetPilot 2610
Sportsworks Transport Bike Carrier
florida_guy is offline   Reply With Quote
Old 03-09-2003, 07:32 PM   #10 (permalink)
kemosabe's Avatar
Default Re: Screen Capture
I take my Nikon 35mm camera and aim it at my 19" computer monitor. When I have used up all 36 shots on the roll, I take the film to Wal-Mart and in 3 days, I go pick it up. I then scan the 4"x6" pictures in.....
Just kidding... I used a package called Paint Shop Pro to do the screen captures... it works pretty well.
Old 03-09-2003, 10:22 PM   #11 (permalink)
havasu's Avatar
All the space is because a break (new line) is inserted for each new line in the post.
To fix this, you can edit your html (before posting is easier) to remove the newlines.
I have to do this in the VIN table thread or there would be over 300 blank lines!! Thanks to admin for pointing this out to me.
'03 Honda Pilot EXL-RES Havasu Blue #20,620 <a href="http://www.honda-pilot.org/forums/showthread.php?s=&threadid=921">Is your VIN in the table?</a>
havasu is offline   Reply With Quote
Old 03-09-2003, 11:10 PM   #12 (permalink)
kemosabe's Avatar
Well, I'll be... thanks, havasu!!! Who would've thunk it was the newlines, huh???
Thanks!!!
1987 Patriot Games
1994 Debt of Honor
1998 Rainbow Six
2002 Red Rabbit
Old 03-09-2003, 11:43 PM   #13 (permalink)
Default Re: Re: Screen Capture
You had me going until you talked about the "roll" of film.
I used to use the shareware version of PaintShop. Still installed on here somewhere. Didn't know it could do that. Thanks for the info.
Options:
Cargo Cover
OEM Hitch
StreetPilot 2610
Old 03-09-2003, 11:51 PM   #14 (permalink)
kemosabe's Avatar
If you're using the shareware version of PSP (ver. 4.12), then go to the Capture menu to setup and start your screen captures...
Old 03-10-2003, 12:11 AM   #15 (permalink)
Just did a search. I have 4.14 zipped up but not installed. Thanks for the info.
Options:
Cargo Cover
OEM Hitch
StreetPilot 2610
