vtm-4 warning light - Honda Pilot - Honda Pilot Forums
Old 01-28-2013, 01:01 PM   #1 (permalink)
Default vtm-4 warning light
HI
My 2010 pilot touring has recently started spitting up a vtm-4 code. Seems to happen on cold days and goes off after restarting once the pilot is warmed up a bit. No noticeable difference in performance, no rough idle etc, and it's not a VTM (traction) issue as this will happen on clear roads etc.
I'm thinking sensor related but just kind of curious if others have had the same problem.
Northern Piper is offline   Reply With Quote
Old 02-11-2013, 08:20 AM   #2 (permalink)
grumpy's Avatar
My 2011 Touring is doing the exact same thing. When I see the vtm-4 remain lit I immediately turn the car off and restart. It always disappears.
The requirement to use my navigation code is also coming on frequently, although not necessarily at the same time.
grumpy is offline   Reply With Quote
Old 02-11-2013, 09:13 AM   #3 (permalink)
Bad battery or loose ground
Old 02-12-2013, 09:16 AM   #4 (permalink)
I agree. it's loose connection or bad battery. (Check the connection before replacing the battery)
2006 Desert Rock Metallic Pilot EX-L w/ RES
2004 track-prepped MINI Cooper S
2007 Toyota Prius Touring
SeaPilot is offline   Reply With Quote
