Tranny oil change - Honda Pilot - Honda Pilot Forums
Old 01-13-2012, 11:26 AM   #1 (permalink)
Question Tranny oil change
Hi,
I just reached the 30k mark on my 2008 Pilot. And, I am wondering if I need to change the tranny oil or not. I was checking the manual and it shows to change it every 30k, "only if you drive in mountains or pull a trailer". I do NOT do either. So, am I supposed to change the oil or not. Please let me know. Also, what else I need to do at this 30k mark.
Thanks for your time,
Ven
pilotven is offline   Reply With Quote
Old 01-13-2012, 11:30 AM   #2 (permalink)
The MM will tell you when to change it https://techinfo.honda.com/rjanisis/...707G00016A.pdf
Old 01-13-2012, 12:02 PM   #3 (permalink)
Change it, great maintenance and will prolong life of the unit!
osudelt69 is offline   Reply With Quote
Old 01-13-2012, 12:12 PM   #4 (permalink)
So, you are saying to wait till I see the code "B3", isnt it?
Please let me know,
Ven
Old 01-13-2012, 01:19 PM   #5 (permalink)
Yes, wait until the MM tells you do any maintenance such as the B3 or B6 (if you have the AWD model) codes. Those codes appear at about 15,000 miles and then every 30,000 after that if I remember correctly.
The coolant should be replaced when you replace the timing belt and plugs in the 105,000 miles range.
I've been following the MM on my wife's 2007 Pilot for almost 120,000 miles so far without any problem other than a radiator that started to leak just a little at about 100,000 miles.
This link contains more information on the MM. Curry Honda Atlanta | New Honda dealership in Chamblee, GA 30341
2007 Pilot LX
2004 Suzuki V-Strom
Old 01-13-2012, 03:29 PM   #6 (permalink)
Hi TomStromie,
Thanks for the link and sharing your experience. That cleared all my questions, and gave me peace of mind. I will wait for the code.
Thanks again for your time,
Ven
