OK, I admit being both stupid and dumb. I filled too much refrigerant in my AC. How do I know? The compressor cycles on/off repeatedly. This was also done by a local mechanic and I had to take it back to the dealer who diagnosed it immediately. So my question is how do I "release" the overfill? Do I carefully release it from the high pressure valve? HELP!
Definitely don't release from the high pressure side. You can press the valve on the low-side to get some out. Just keep in mind this is not really legal to vent to the atmosphere. Of course you won't get in trouble unless the EPA is watching you.
How did you fill your AC? Did you use a gauge to watch the psi as you filled? |
Never charge without a gauge. Autozone sells a all-brass r134a gauge with built-in can tap for $20. This is good enough to top off a low system. There is even an extra bezel on top you set to the current outside temp to give you a smaller window of ideal low-side psi.
Even with a gauge it's hard to tell if you have the right amount because your supposed to charge by weight. That means a vacuum must pull all old refrigerant out, and then you add the proper amount to the empty system. Even still, this gauge-filler will get your AC going again. Quest/R134a recharge hose with metal gauge handle (401GMCS) | A/C Manifold Gauge Set and Components | AutoZone.com |
Your right, but you don't want to be pressing the valve on the high side cause of the higher psi is more dangerous.
The low-side is actually lower psi when the AC is running. When it's off it generally equalizes between the two sides. I still don't mess with the high-side just because... |
