A search would pull up an old thread asking this very question:
2008 Pilot, Where is the transmission fluid drain bolt?
I just did my 2008 yesterday. The fill bolt is on top under the brake fluid and it's easier than the dipstick in my opinion. The drain bolt uses the square head of the ratchet to open it.
Thank you so much OhioBobcat20000. I took a picture of the many bolts but can't dowload it. The "square head" bolt is the third bolt counting from the front and is round so you can't use a wrench. My Camry also had this arrangement
Check these pictures:Easy DIY ATF Fluid Change PICs
#9 (permalink) | |
It is the same, the tip of the 3/8" square drive is all you need to remove the drain bolt. This is depicted in the DIY instructions as shown by the blue line in the picture. Where the milk jug is collecting the fluid. Take a close look at the tool being used in OP post to start the DIY.
The fill bolt on some vehicles is marked boldly with an ATF stamp and is located directly below the brake fluid reservoir.
____________ 2005 EX-L 4wd WEATHERTECH* Floor liners, cargo liner, bug/wind deflector (Direct Order). CURT*Trailer hitch /harness/Transmission and Power steering coolers (etrailer). OEM *Crossbars and rear splash guard (HandA). OEM* Foglights (Ebay/yourkeylessremote). DEI * 452t Automatic Door Lock Modification (Sonixelectronics). MAXXIMA*M09300 Side Marker LED light Modification (Partssystems). SEARS*16009 Oil Catch Can Mod (Sears). Coffee ! Is The Planet Shaking or Is It Just Me ? Last edited by cofetym; 07-10-2011 at 04:26 PM. |
It is the one as pictured. The person marked it with a blue marker line. Perhaps yours is painted blue as well but on my car the paint was very faded off. I believe it is the only bolt on that side (closest to the front driver's side wheel) with a crush washer and a 3/8" square head.
