Guys,
I needed to replace the keyless entry batteries in my two keys and am having considerable difficulty in programming my 2006 Pilot to accept them. I've found the directions here on Piloteers and have followed them exactly, but i cannot get the Pilot to enter "programming mode". After reading the other threads, it sounds like others have also had difficulty with this. I was very careful to observe the timing, but I'm not having any luck. Any other suggestions out there? Steve |
#2 (permalink) | |
I think what happens to most people is that after changing the batteries, they THINK they have to reprogram the remotes and then they try to do the programming procedure and end up wiping out the programming in the vehicle. I'm not saying this necessarily happened to you, but just trying to understand what happened in your case. Last edited by megatron; 05-30-2011 at 03:25 PM. |
So perhaps both my remotes are bad??
One stopped working around 2008, replaced the battery and it still didn't work. So I thought that one was dead. The other has been working until just recently, so i figured the battery died. I replaced the battery and it still didn't work. That's when I started researching this problem on the Piloteers boards and saw the procedure for programming the car to accept new remotes. Is there any way to determine if the remotes are functioning? By the way, what is that very small button on the remote module - a reset? Thanks again for the help. |
If you have fresh batteries in the remote and they are installed correctly, but you get no light when you press a button, your remote is toast. Get a new one (or two). |
Yes classic sign of defective remote.
I didn't realize that was a light - so its confirmed that I have two dead remotes. It appears that I can get a couple of OEM blank keys with the remote module for under $40 each. I can swap out the modules from those. Is there anyplace where I can get just purchase the remote module?
Brand New OEM Honda Pilot Master Key w/remote 2005-08 | eBay I bought 3 keys from the above and they were perfect, unopened, genuine Honda keys/remotes, so I can say for sure that it is an excellent deal at $25 a piece shipped. He even mentions your specific case of swapping the remote module for a broken one to fix your key. Good luck! Last edited by megatron; 05-30-2011 at 09:25 PM. |
Glad you took advantage of that link!
I was a bit skeptical when I first found it myself, but like I said, I bought 3 and actually got exactly what he described so I was happy! I don't know how he makes money on them, but I didn't mind and didn't ask. I just got my keys and ran! ![]() Maybe he works at a dealer and can get them below cost? |
