Body work help! - Honda Pilot - Honda Pilot Forums
Old 04-20-2011, 10:34 AM   #1 (permalink)
Default [Repairs done - photos inside] - Body work help!
I have a few body work / paint job fixes that I need on the rear bumper - some plastic damage and paint chips
Question - can the plastic be cured or put back in shape ? Is is one unit all the way around the whole bumper ?
any help will be appreciated
matchan1 is offline   Reply With Quote
Old 04-28-2011, 11:08 AM   #2 (permalink)
People,
I need some help with this.... Any knowledgeable folks?
Old 04-28-2011, 01:02 PM   #3 (permalink)
the bumper cover can be sanded and spot painted, the lower gray trim might be able to be popped back out and if so, you could try to match the gray paint. i believe it is one whole piece all the way around.
Old 04-28-2011, 01:34 PM   #4 (permalink)
Thanks. Can I really paint the lower trim ? Its plastic..
Old 04-28-2011, 02:05 PM   #5 (permalink)
Yes, you can paint that plastc trim as I have done on my 05 Pilot. Clean with Silicone and Wax remover only, not anything else or will not work right. Use Duplicolor Adhesion Promotor first and then Duplicolor Bumper Coating. These can be found at Autozone or Pep Boys. However, grey may be hard to find, might have to order it. Black is easiest to find in stores. Some guys use Krylon Fusion paint with good results, too. SEM and other commercial quality paint manufacturers also make plastic bumper/trim paint in aerosol cans but you would have to go to an automotive paint supply store to find that.
2005 LX 4wd
OEM accessory roof bars
OEM nerf bars
OEM rear splash guards
2006 OEM 4wd emblem
Garmin GPS
Aftermarket tinted windows
OEM accessory fog light kit
OEM accessory cargo cover
Silver painted grill
Acura stainless exhaust tips
KYB GR2 struts/shocks
Curt 13328 Hitch
Old 05-05-2011, 12:02 PM   #6 (permalink)
thanks mclairmo
Old 05-05-2011, 12:08 PM   #7 (permalink)
Fixed by a touch up genius -$50
Old 05-05-2011, 12:10 PM   #8 (permalink)
He used a hot air gun, sand paper, buffed, painted and used the heat to melt part of the plastic to re-bond with itself. 1 hour, $50. I'm very happy!
Old 05-06-2011, 06:00 AM   #9 (permalink)
Nice work! Looks real good...
Checking all my options...
Justrfb
justrfb is offline   Reply With Quote
