Coffee Maker? - Honda Pilot - Honda Pilot Forums
Old 01-17-2011, 01:44 PM   #1 (permalink)
Default Coffee Maker?
Have a 2010 Pilot Touring 4WD. I go up to the snow a lot and want to try to hook up a coffee maker to the outlet inside the car. Has anyone tried this and had success? Having trouble find a coffee maker or water heater that would work with the 110v outlet.
Is it even possible?
2010 White Pilot 4WD Touring R&N
mcgong is offline   Reply With Quote
Old 01-17-2011, 03:54 PM   #2 (permalink)
RSQ Pilot's Avatar
Garage
Hard if not impossible to find a 115 v coffee maker @100 watts or less. 100 watts is the maximum draw before the Honda 115 outlet shuts off.
"Always run the engine when you use
the AC power outlet.
The maximum capacity for this
power outlet is 115 volt AC at 100
watts or less. If you use an appliance
which requires more than 100 watts,
it automatically stops supplying the
power. If this happens, turn the
ignition switch off and turn it on
again."
There are some 12v Trucker/RV style coffee makers with or without internal DC>AC inverters or you could install a higher wattage DC>AC inverter. (beware of amperage draw limititations on your standard 12v wires)
http://www.12volt-travel.com/12-volt...kers-c-92.html
12 Volt Coffee Makers - 12 Volt Coffee Maker - 12V Coffee Makers - 12V Coffee Maker - Java to Go Coffee Cup
Old 01-17-2011, 07:54 PM   #3 (permalink)
rclark's Avatar
Buy a power inverter
2004 EX-L; Sage Brush Pearl; 5000K HID's; 6% Tint
rclark is offline   Reply With Quote
Old 01-18-2011, 11:37 AM   #4 (permalink)
Nice info on the coffee maker. Since we're talking about wattage...how about the Wii console? I believe the Wii's power adapter is on 110V to 120V and consumes on the average 18-20 watts. Has anyone played Wii on their EX-L RES?
2011 Honda Pilot EX-L RES Bali Blue Pearl
Chrome Side Steps
MarlonRibunal is offline   Reply With Quote
Old 01-18-2011, 04:39 PM   #5 (permalink)
RSQ Pilot's Avatar
Garage
You are good up to 100 watt draw at 115 volts. That easily covers the WII
One thing to note is that some 90 watt chargers for laptops or other high wattage battery chargers may peak occasionally at a higher than a 100 watt draw easpecially if the battery is completely drained. When this happens it could shut off the inverter and quit charging.
Old 01-18-2011, 05:07 PM   #6 (permalink)
Most domestic coffee makers are watt hogs and the stock unit is unlikely to be able to handle the power demand.
Old 01-23-2011, 04:40 PM   #7 (permalink)
Power Inverter to the rescue.... run whatever you want in good ole DC!
pesto126 is offline   Reply With Quote
