Need recommendation for an ODB-II code reader - Honda Pilot - Honda Pilot Forums
Old 12-13-2010, 05:45 PM   #1 (permalink)
Default Need recommendation for an ODB-II code reader
Now that my Pilot is showing CEL light, I need to pull the codes. Hope someone can recommend a good but not too expensive code reader for ODB-II cars.
Appreciate any suggestions.
Bob
oldtrlrnr is offline   Reply With Quote
Old 12-13-2010, 06:19 PM   #2 (permalink)
cofetym's Avatar
Found this in the search forum hope it helps.
Amazon Amazon
http://www.scantool.net/elmscan5-compact.html
http://www.myscantool.com/
SCan Guage Computer
____________
2005 EX-L 4wd
Old 12-15-2010, 06:55 PM   #3 (permalink)
rclark's Avatar
Bob
If there's an Autozone near you they will read the code for free.
2004 EX-L; Sage Brush Pearl; 5000K HID's; 6% Tint
rclark is offline   Reply With Quote
Old 12-15-2010, 07:12 PM   #4 (permalink)
I have the OBDLink, which is a bit newer than the Elmscan. It works well. You can buy through them, or Ebay for about $85 for the ObdLink, and 50 for the Elmscan.
2007 Pilot 4wd EX-L Nimbus Gray
2010 CRV 4wd EX-L Urban Titanium
RonnieJ is offline   Reply With Quote
Old 12-15-2010, 08:53 PM   #5 (permalink)
cwa107's Avatar
Actron makes nice, basic code scanners that are relatively inexpensive. I have this one and it does a good job. No frills, but it can fetch and clear codes. Also comes with a CD that deciphers the codes (although you can just as easily Google them).
Amazon.com: Actron CP9125 PocketScan Code Reader: Automotive Amazon.com: Actron CP9125 PocketScan Code Reader: Automotive
Old 12-15-2010, 09:00 PM   #6 (permalink)
samc's Avatar
I'd be curious for one as well. Preferably something usb with more then just code reading and removing.
Old 03-27-2012, 09:15 AM   #7 (permalink)
94eg!'s Avatar
Here is how you check for VTM light, D light or Check Engine Light codes without an OBD2 or Honda scan-tool (OBD2 scanner can't pull D and VTM codes anyways)...
Originally Posted by 94eg!
Just grab a paper clip and read the codes yourself. Stick the paper clip in the DLC by the drivers right knee (as shown in this picture). Then switch the ignition to the "ON" position and watch all the lights start blinking. Long blinks are 10's & shorts are 1's. Just add them together to get the code for that light. If there is more than one code stored, they will be separated by a break between blinks:
This link has the definition for all check engine light blink-codes:
K20Tuned LLC*::*DC5/EP3 Codes
Here is a link to the VTM light blink-codes:
http://rsgear.com/articles/2006_12.pdf
And here is a link to show the Transmission "D" light blink-codes:
flashing shift indicator
Write down all your codes and come back to THIS thread and let us know.
Old 03-27-2012, 10:01 AM   #8 (permalink)
I have one bought when a Volvo we had was being a PIA showing codes every week or so. Useful to know what the codes were, but since then, the need for it has disappeared. Since you'll never get Honda specific codes on a generic reader, get the cheapest you can, with a wire that allows you to drive the car and monitor whats going on.
Old 03-27-2012, 06:53 PM   #9 (permalink)
I have the Innova 3160.
Google it or check out eBay. It can be purchased for just under $200 and is great for codes, live data and ABS codes on certain cars (not Honda)
Old 03-27-2012, 07:14 PM   #10 (permalink)
You guys do realize this thread is over a year old. Hopefully the OP has fixed the problem or has sold the Pilot to make it someone else's problem.
Old 03-27-2012, 09:20 PM   #11 (permalink)
ARRRG!
I hate when I do that!
Old 03-27-2012, 10:06 PM   #12 (permalink)
94eg!'s Avatar
I fell for it too.
Old 03-27-2012, 10:42 PM   #13 (permalink)
I think this qualifies as brought back to life by spam.
Were any of you brave enough to click on that link? One post one link to??
Old 03-27-2012, 11:59 PM   #14 (permalink)
Well yes, I did start this thread over a year ago. IIRC the problem turned out to be premature trans failure. I bit the bullet and had the dealer put in a rebuilt trans - Honda gave me some comp funds, but not as much as I thought they should have. The car has been running fine since then.
I still want to get an ODB-II code reader, though the need is not urgent right now.
94eg!, thanks for the tip on the procedure to read the codes from the blinking pattern. That's the way I read the codes on my '87 Toyota MR2. I'll save that info.
Thanks again, all.
- Bob
Old 03-28-2012, 07:19 AM   #15 (permalink)
On my current vehicle, I use a very cheap ELM bluetooth dongle.
Then I use an app on my Android phone to read and reset the codes. I think I paid less than $20 total. It isn't the best, but it works well for the price.
BAlGaInTl is offline   Reply With Quote
