Steering Issue - Honda Pilot - Honda Pilot Forums
Old 12-03-2010, 09:44 AM   #1 (permalink)
Default Steering Issue
On my 03 pilot I've been noticing that my steering is staring to feel loose. It's seems that my wheel turns too easily. If I run over even a small stone or something my wheel wants to turn. Even on dry pavement it feels like I am driving on ice. I have replace the struts and mounts already. Anybody have any thoughts on this?
at03pilot is offline   Reply With Quote
Old 12-04-2010, 04:52 PM   #2 (permalink)
If the struts and mounts are getting replaced anyway, now is the time to get the alignment checked and adjusted also. An alignment issue is my first guess.
Are the tires in good shape and inflated properly? Is there any "play" in the wheel, as in, can you turn the steering wheel any distance without the wheels actually moving? Any weird noises when you steer? How does it behave on wet roads? Are you hauling anything heavy in the back? How's the power steering fluid level? Is the steering effort the same whether you're moving or not?
LetsGo is offline   Reply With Quote
Old 01-12-2011, 03:58 PM   #3 (permalink)
PILOTHEAD's Avatar
Identical issue and seemingly almost identical vehicle and region, going to check fluid level, appreciate if OP can post solution and i will do the same.
We had Timing belt changed late summer and wondering if that had anything to do with it?
2003 EX Sage Brush Pearl, Lo Jack, Crossbars, Rear Splash Guards, All Season Mats, Cargo Tray, Cargo Liner, Wheel Locks
PILOTHEAD is offline   Reply With Quote
