What are the proper torque specs for lug nuts - Honda Pilot - Honda Pilot Forums
post #1 of 8 (permalink) Old 08-01-2008, 02:27 AM Thread Starter
Hi All,
What are the proper torque specs for the lug nuts of the wheels on the pilot?
I am doing a rotation and wanted to know how many pounds to adjust my torque wrench to.
Spartus is offline
post #2 of 8 (permalink) Old 08-01-2008, 03:19 AM
Super Moderator
It should be about 85 ft/lbs.
humanoid is offline
post #3 of 8 (permalink) Old 08-01-2008, 10:01 AM
NJGuy's Avatar
I'm guessing you have a 1st gen Pilot. The owner's manual says 80 lbf-ft (ft-lbs) for the '03-'08 models. The '09s are different and call for 94 lbf-ft.
NJGuy is offline
post #4 of 8 (permalink) Old 08-01-2008, 03:39 PM
Wolfman_matt's Avatar
When I was getting a new tire installed at Discount Tire earlier this week I asked that very question to the technician doing the work.
He said they torqued mine to 80 fl-lbs. I'm not sure how they determined that but I was happy to see them firm up the lugs with the gun and then finalize the proper torque setting by hand with a torque wrench.
2003 Sagebrush Pilot EX
240k miles
I-VES DVD
fog lights
MDX Wheels
Chrome side steps
chrome grill and handles
Yakima Rack
Woodgrain steering wheel
Wolfman_matt is offline
post #5 of 8 (permalink) Old 08-02-2008, 01:37 PM
Sorry for the hijack.
What size of the socket for the wheel nuts?
I am looking to buy for rotating the tires
2008 Pilot SE 2WD Silver
OEM Running Board, OEM Cargo Tray, OEM Moon Roof Visor, P2 Brake Controller, Front/Rear Hitchs, After market AT/PS Coolers, Full Size Spare Tire, Husky Liner,
Happydady is offline
post #6 of 8 (permalink) Old 08-03-2008, 09:16 AM
Sportymonk's Avatar
Wonder why the 09's have a higher torque? What changed or did Honda simply feel it is safer?
I thought there were only two torque settings:
(1) As tight as I can get them where I can get them off again (yes honey that's's tight enough) and,
(2) Tire dealer tight which is so tight an 800 lb gorilla jumping on the lug wrench can't bust them loose. (Usually discovered on a dark and rainy night!)
Sportymonk is offline
post #7 of 8 (permalink) Old 08-03-2008, 12:13 PM
Yep, 80ft lbs. I'm always pleased when the tire shop uses a real torque wrench to finish them off.
The lugs are 19MM.
At home I use an 80 lb torque stick on an impact gun. I've found it to be pretty darn accurate.
stubble is offline
post #8 of 8 (permalink) Old 08-05-2008, 09:21 AM
NJGuy's Avatar
If you don't have one already, also buy a short extension for the socket (maybe 4" or so). That will give you a little bit of clearance for your hands between the tire and the torque wrench.
NJGuy is offline
