No overdrive - Honda Pilot - Honda Pilot Forums
Old 08-18-2007, 09:11 PM   #1 (permalink)
Default No overdrive
On the return leg of a 600 mile road trip my 2004 Pilot would not go into overdrive. Engine RPM reflected about 4000 but no power. I kicked off the cruise control and still same problem. We crippled home with no other problems. No check engine light illuminated or adverse indications. I checked my K&N filter and no clogs. Any ideas please help before I have to take it to the dealer.
izi6969 is offline   Reply With Quote
Old 08-18-2007, 10:18 PM   #2 (permalink)
krygny's Avatar
Default Sounds serious
Not likely something that will "just go away" with a filter or fluid change and some wishful thinking. 4000 RPM at what speed? At 70 MPH, almost seems as though it was stuck in 3rd.
2003 EX-L, Sage Brush Pearl
Old 08-18-2007, 10:40 PM   #3 (permalink)
Are you sure the selector was not in "D3"?
Old 08-19-2007, 08:51 AM   #4 (permalink)
I was driving at about 70 mph through some rolling hills etc. Running 87 octane gas, like always. Vehicle was in "D" and 4 passengers and some luggage. Not extremely overloaded and ambient temp was about 91-93 degrees.
Old 08-19-2007, 09:41 AM   #5 (permalink)
krygny's Avatar
Come to think of it, 4000 RPM @ 70 MPH sounds a little high even for D3. You may have driven 300 miles in 2nd gear on a hot day up and down hills with a full load. I wish I could think of something good to say but I think the tranny's F&%KED. Hope you're still in warranty.
Gear Ratios:
1st: 2.693, (2WD, 2.422)
2nd: 1.565
3rd: 1.023
4th: 0.782
5th: 0.595
Reverse: 1.888
Final Drive: 4.375
(Current models; may be different in '03s &'04s.)
Old 08-19-2007, 02:13 PM   #6 (permalink)
jestmaty's Avatar
Feedback Score: 1 reviews
Remember, I'm one of the few/or many that use D3 regularly... when I'm towing.
Came back from Austin To Houston in D3 with my boat behind me. Got 3500 rpms @ 60 mph, so 4000 @ 70 sounds about right.
No one has asked the question yet.... is it still not going to 5th or is it still stuck seemingly in 3rd?
2004 EXL-RES Sage Brush Pearl
2005 Bayliner 175XT Bowrider
Old 08-19-2007, 03:45 PM   #7 (permalink)
Just did a test.
4000 is about right for 70 MPH in D3.
Might just be a linkage problem.
Stop worrying and have it looked at.
Old 08-19-2007, 11:48 PM   #8 (permalink)
Is this a lack of power problem or a transmission gear selection problem?
Old 11-28-2007, 01:04 PM   #9 (permalink)
A6Pilot's Avatar
izi6969-
One operating characteristic of Japanese engines is that they need high rpm to achieve power. The Honda powertrain engineers have designed their transmissions to account for that. The transmission will try to keep the engine operating in the upper reaches of the powerband. Heck, the vtec feature doesn't even engage until your north of 4000 rpm.
Even with a slight incline, the transmission will first unlock the torque converter, then shift down to a lower gear. It remembers how aggressively you like to drive, and will shift earlier to accommodate those folks. The transmission has been programmed to retain a lower gear selection longer, to prevent constant shifting. It's just the way it is designed.
4000 rpm at 70 mph is about right for 3rd gear, and unlocked torque converter.
It sounds like your vehicle is operating exactly as designed.
