4 Infinity REF-6502ix Installed. Still lacking Mid-Range :/ - Honda Pilot - Honda Pilot Forums
Old 01-31-2013, 09:09 AM   #1 (permalink)
Default 4 Infinity REF-6502ix Installed. Still lacking Mid-Range :/
I installed 4 new Infinity REF-6502ix in my 2003 Honda Pilot. The installation was a lot easier then I thought. A bit tricky at times with the wiring, but I would not hesitate to do it again. Crutchfield is terrific BTW.
The sound is much better! But...I am still lacking mid-range. Is there any, easy, solution to this? Would a new stereo change the mid-range, or sound of these speakers? And, if it is the head unit that is needed, is there one that can still work with the steering wheel changer and control the DVD system?
TIA
Snow is offline   Reply With Quote
Old 01-31-2013, 09:28 AM   #2 (permalink)
rocky's Avatar
You likely need not only a sub with amp but also a head unit able to properly power those speakers
Sent from AutoGuide.com App
Old 01-31-2013, 10:25 AM   #3 (permalink)
Hi Rocky. I think I could do without the sub totally. Too mushy.
I was on chat with Crutchfield and the guy recommended an amp---> Alpine MRP-F300 V-Power Series 4-channel car amplifier — 50 watts RMS x 4 at Crutchfield.com
Would a new head unit work with my steering wheel controls? And would it add power to the speakers like an amp would? Or at least enough power to make these speakers sound the way they should?
Old 02-04-2013, 01:27 AM   #4 (permalink)
replacing the head unit will lose control and operation of the rear entertainment dvd system. I did that and knew about it. Steering wheel controls can be kept by adding a harness to the new radio and splicing into the wiring harness. Yes definitely a new head unit will better utilize your new speakers but if you don't want to lose the rear dvd unit then try adding an amp.
2004 Pilot EXL-RES, 92K miles.
pilot_rave is online now   Reply With Quote
Old 02-04-2013, 04:49 PM   #5 (permalink)
Thanks p_r
That is what I found out as well from Crutchfield. I do not care about the DVD player, but I am afraid that the car will loos value when I sell it :/ Otherwise I would just kill the DVD and ad the head and steering wheel controller.
