'Mode Restriction' on 2011 RES - Honda Pilot - Honda Pilot Forums
Old 11-05-2011, 12:24 AM   #1 (permalink)
Unhappy 'Mode Restriction' on 2011 RES
So I had my iPhone plugged into the USB port and the Front Source was set to USB/iPod. I turned on the Rear Source for my daughter sitting in the back. She tried to change the Rear Source to XM and a message 'Mode Restriction' appeared on the rear display.
I changed the Front Source to XM and then my daughter could control the XM radio channel etc. in the Rear Source.
When we returned home I sat in the back and tried it myself. Sure enough, when the front is set to USB/iPod, the rear Source says 'Mode Restriction' when you select XM. As soon as I change the Front Source to anything other than USB/iPod, the Rear Source shows and plays the XM radio.
Anybody else see this? I looked in the manual and it mentions nothing about restrictions other than some parental control setting, which I haven't checked yet and I don't think is enabled from the factory.
2011 WDP/Black Touring 4WD
2008 Toyota Prius Touring
2007 Mazda MX-5
pearsonrj is offline   Reply With Quote
Old 11-09-2011, 12:32 PM   #2 (permalink)
mobro's Avatar
My 2009 touring is the same way. I couldn't find anything in the manual about it either.
mobro is offline   Reply With Quote
