RCA cable ouputs? - Honda Pilot - Honda Pilot Forums
Old 10-06-2011, 08:45 PM   #1 (permalink)
Default RCA cable ouputs?
Im looking for more bass and don't want to buy a new head unit. I want to install an MTX RT8PT Road Thunder 120-watt powered 8" subwoofer. Does the 2004 honda pilot have RCA cable outputs, and would this even be possible?
Hitman374 is offline   Reply With Quote
Old 10-06-2011, 10:34 PM   #2 (permalink)
If you have RES you only have inputs in the rear of the console. Not without an adapter USA Spec/Blitzsafe etc
BTW, no need to post twice, delete the other thread!
Old 10-07-2011, 03:44 PM   #3 (permalink)
You posted twice, I'm replying twice...
The MTX amplified sub box has speaker level inputs. No need to add RCA's. The facroty subwoofer is in the Right Rear side panel. It is powered by the radio in the dash. The wire colors are white/green (+) and black/white (-). Personally I would unhook the factory sub so that you don't get cancellation/spikes and just run off the MTX unit.
tjamz is offline   Reply With Quote
Old 10-28-2011, 01:01 AM   #4 (permalink)
The least expensive way is to run the speaker leads off the factory radio into the "speaker level" inputs of any bass amp. If the bass amp does not have speaker level inputs, then you can get a line output convertor that will take the speaker inputs and convert them into a low level RCA cable signal and then run RCA cables to a bass amp.
If you had a bigger budget, look into an add on processor that will take all your speaker inputs, clean up the signal, then run many RCA clean signal channels out to bass, mid, and high amplification.
'04 EX-L, Alabaster Silver Metallic, front bumper lower trim, OE fogs w/yellow H3 bulbs, OE running boards, OEM tow package, backup sensors, Alpine CDA-9887, Alpine PDX-5, Polk Audio SR6500, Alpine Type R 10 inch shallow sub in factory location, Compustar security with remote start.
Toy Civic is offline   Reply With Quote
