Brand new Pilot owner! - Non-iPod solution? - Honda Pilot - Honda Pilot Forums
Old 08-29-2011, 07:46 PM   #1 (permalink)
Default Brand new Pilot owner! - Non-iPod solution?
Hello everyone.
I'm soon to be a new Pilot owner, new to our family anyhow. I just bought a minty 2006 EX-L w/NAV today, super clean. We've been Honda owners since 1985, but never a Pilot.
My only dissapointment with this acquisition is the abscence of any kind of AUX input. Years ago I would have been thrilled with the 6 CD changer, but now I know we won't use it at all.
I searched the forum a few times and come up with some possible solutions to overcome this problem but nothing that seems spot on. Most of the threads I found were a bit old.
What I'm trying to do:
- ideally: a USB in that would allow both charging and audio (I use an android phone right now).
- really ideal: the same but with steering wheel control (I know, I'm dreaming)
- minimally: simply add a straight mini stereo input
Any ideas would be appreciated.
Cheers!
Abouna is offline   Reply With Quote
Old 08-29-2011, 08:59 PM   #2 (permalink)
The least invasive solution is a FM modulator. The sound quality is not tghe best but it is the easiest and least expensive way to go. Next you can find a iPod integration (Honda or aftermarket) kit that would need some experience with connecting car audio. Many modulators utilize the CD changer input that is already built-in to your factory stereo.
Hope that helps.
2010 Pilot Touring w/Ent+Nav, OEM premium running boards, OEM cross bars, WeatherTech bug shield, WeatherTech rain guards, WeatherTech floor mats, WeatherTech rear cargo liner, and BROKEN moon roof with fuse pulled (now fixed).
sxl08md is offline   Reply With Quote
Old 08-29-2011, 10:15 PM   #3 (permalink)
Hope that helps.
Shoot, I should have thought to say I'm interested in an invasive method here. I've done the whole modulator thing and it's less than satisfying.
Old 08-30-2011, 02:21 PM   #4 (permalink)
Default IPOD Solution
Assuming your Pilot has a cassette deck, Best Buy carries a cassette adaptor which has a mini-plug to connect to an IPOD. Insert the cassette adaptor, select 'tape' on control panel and plug adaptor into IPOD - works fine using radio's audio controls.
tfshea is offline   Reply With Quote
Old 08-30-2011, 02:36 PM   #5 (permalink)
Just call me doofus for not thinking of listing everything.
No, no tape deck. I definitely want to hardwire this in. I'm not scared of tearing the dash apart, but I'd like to know the best solution.
Old 09-13-2011, 10:55 PM   #6 (permalink)
Axxess Interface - Vehicle Guide
1. select your year/make/model
2. select the type of input you want (Ipod/Zune/Aux/etc...)
3. click on the models that pop up, most likely you will need to piece together a system based on the solutions that are provided. Their website kinda sucks at telling you what you need, I'd suggest DL'ing the install manual, it should give you clues as to which pieces are required. You should be able to use the following items from them: I *THINK* that the XIA-LCD is optional, but you may want to double check.
Axxess XIA-I01
IMPORT VEHICLE AUXILLARY INPUT DEVICE - IPOD, VIDEO, MP3
Axxess XIA-LCD
LCD Repeater Display for iPod Interface
Axxess XIAH-HD3
ACURA/HONDA SPECIFIC HARNESS FOR XIA-I01
Axxess XIAH-IPC
IPOD CABLE FOR XIA-D01/XIA-I01/XIA-EU1
Axxess XIAH-RCA
AUXILLARY INPUT CABLE FOR XIA-D01/XIA-I01/XIA-EU1
tjamz is offline   Reply With Quote
