2006 In-dash CD Changer ejects, won't load - Honda Pilot - Honda Pilot Forums
Old 03-21-2011, 03:55 PM   #1 (permalink)
Default 2006 In-dash CD Changer ejects, won't load
I have a 2006 EX Honda Pilot. The CD changer has been working fine, but a few weeks ago, I found that it wouldn't load CDs. I can eject CDs already in there, but when I try to load, it takes in the CD 1/4" then switches to "Busy" and tries to go back to the first CD.
Has anybody seen this before? Is there an easy fix? Maybe power cycling the unit from the fusebox or something?
Thanks in advance for any help you can provide.
drolen38 is offline   Reply With Quote
Old 03-22-2011, 12:12 PM   #2 (permalink)
cofetym's Avatar
Default Welcome.
Mine went out several months ago. They are very expensive to replace via the dealer and repair is not cheap. You could try the fuse method or disconnecting the battery. If you disconnect from the battery you'll need your radio code and reset the one touch driver window in the manual.
You can also check Ebay or take this as an opportunity to slowly upgrade the system.
____________
2005 EX-L 4wd
