During a road trip smoke started pouring out of the dashboard around the radio. We turned it off quickly and it stopped smoking. Is this common? Does anyone know if there is a TSB or a recall on the audio control?
Also, will a newer unit fit in the 2003 dash? I would like to get rid of the cassette deck. It will have to control the DVD as well. Thanks, Mike |
You are the first one I recall hearing about.
If you want plug and play you probably have to stick with an '03 (or maybe an 'o4, or '05with some investigation.) A good audio shop that knows Hondas might give you some better advice. I doubt you are going to find anything that gets a DVD up there without going aftermarket.
