Parking Break Lead - Honda Pilot - Honda Pilot Forums
Old 10-30-2010, 10:24 AM   #1 (permalink)
Default Parking Break Lead
I've searched and searched the internet and I cannot find the information I need. I'm looking for the location and wire color of the parking break lead wire. I am installing a navigatio unit and need to tap into this. I do not wish to bypass this. Any help would be amazingly appreciate on this end!
ndavenport is offline   Reply With Quote
Old 10-30-2010, 12:33 PM   #2 (permalink)
What year is your car? You just want to know what color the wire is that turns the brake light on when you put the parking brake on?
Old 10-30-2010, 12:59 PM   #3 (permalink)
It's a 2006. I need the color and location of the positive lead wire for the parking brake so the navigation unit knows when the brake is engaged, not the brake light.
Old 10-30-2010, 01:11 PM   #4 (permalink)
ED27's Avatar
There's a small connector slightly above the parking brake pedal. You should test the lead (GRN/RED) with a DMM. It will show ground when the parking brake is engaged. If your new unit truly requires a positive 12v signal, you'll need to convert the signal using a relay.
2004 EX-L NBP
Old 10-30-2010, 02:24 PM   #5 (permalink)
Found it! Thanks for the info.
