the athlete
Guys, can anyone give a definite yes/no if this would fit a 2005 Pilot?
Rockford Fosgate P3SD210 Punch Stage 3 Shallow 10" subwoofer with dual 2-ohm voice coils Rockford-Fosgate-P3SD210 Crutchfield has it pop up when I search under my vehicle, but I have read many threads that say none, or not many, aftermarket subs fit in our stock location. I wonder if the stock amp would even do this justice, as it is 100-300 watts rms. It is 2ohm which I believe our sub is. Thoughts? Thanks in advance.
05 Honda Pilot EX-L, Nighthawk Black Pearl/Saddle Mods: splash guards; weathertech mats; rear cargo tray; 18" MSR black rims; 265/60/18 Falken Ziex; debadged Pilot emblem; McGard 65557BK black lugs/locks set; WWongs Console Pads; Installing: 4x Polk Audio DB651s slims; |
Fits like a glove, i have the same Sub in my stock location. You will need to use the spacer ring to get it to fit well. I believe if you search the forum for "yaswu" is the thread i used to get info before i installed mine. I wouldn't waste your time trying to power it off the factory amp, you definitely want to add an amp to put some real power to it.
