New Unit Install - Honda Pilot - Honda Pilot Forums
Old 05-19-2010, 07:37 PM   #1 (permalink)
david.shain's Avatar
Default New Unit Install
If I install a new head unit, say a Pioneer Double DIN DVD/GPS/CD unit, and if I use a wiring adapter kit to plug the system into the vehicle factory wiring, will I have to bypass the factory Amp and possibly the factory woofer? This occurred when I installed the unit in my 2007 Civic EX. The only thing that worked after that was the door and rear speakers with only the unit power. Did this post make sense? Thanks
Sarge!
Customs: Infinity Speakers, HFP 17" Wheels, '06 Pilot Clear Tails w/LED Bulbs, Sylvania Headlight Bulbs
david.shain is offline   Reply With Quote
Old 05-20-2010, 12:38 AM   #2 (permalink)
The factory sub is nothing to be proud of and worth replacing if you making that kind of investment in your cars.
Old 05-20-2010, 07:38 AM   #3 (permalink)
ED27's Avatar
Originally Posted by david.shain View Post
.....will I have to bypass the factory Amp and possibly the factory woofer?
The 1st gen Pilots do not have a factory amp - all of the speakers are powered by the head unit. You will lose the factory sub unless you add an amp. If you go the amp route, I would consider upgrading the sub as well.
2004 EX-L NBP
Old 05-20-2010, 07:56 PM   #4 (permalink)
Well allrightythen, a new head unit it is! I have a Memphis Amp and a 8" free air woofer I can install and call it a day! Thanks for the info!!!!!!
Sarge!
