Currently, I am playing video with WDTV + hard drive connected to RSE of my Pilot.
Wanting to buy a video Ipod to replace them but not sure how it works: -Connection: can I just use 3.5mm to rca (yellow+red+black) cable connect ipod and RSE? -How bis is file converted from 5gb iso to mp4 in order to play i ipod? -For charging ipod, can I buy Ipod's home charger and use the outlet in the Pilot like I am using with WDTV now?
2008 Pilot SE 2WD Silver OEM Running Board, OEM Cargo Tray, OEM Moon Roof Visor, Full Size Spare Tire, Husky Liner, After market AT cooler |
This is what you need to connect to video and audio. It also allows you to charge via your normal charger while plugged into the center console outlet. I was using this in my 06 for the last 3 years and worked perfectly (ipod classic).
http://store.apple.com/us/product/MB...co=MTA4MjUwMzk Not sure about the file conversion question. Hope that helps.
2010 4WD Touring RES Silver/Gray, Clear Bra, Prem Running Boards, Cargo Mat, All Season Mats, Rear Seat Covers, Fenderwell Trim, Accessory Grill, 55% Tint All Around 2006 4WD EX-L RES 10/06-2/10 |
Thanks for replying.
I ordered used Ipod 30gb 5th generaion on ebay. It is on the way. And I also ordered this cable. Hopefully, it will work well with Ipod. If not, I only lost 4 bucks. Link: http://cgi.ebay.com/ws/eBayISAPI.dll...m=110510397576 I tried convert 2hr, 5gb movies last night to mp4. It is about 750mb, not bad. Can't wait to test it out on Pilot.
I would use handbrake to covert the videos. It has presets for each type of iPod, iPhone, and AppleTV. Not sure if the iPod can play a video file that has a higher resolution than the screen. I would give it a try though as your monitor probably has a higher resolution than the video iPod.
Handbrake: http://handbrake.fr/
Yes, I have been using handbreak to convert the video. The original video file is sd dvd ripped. it was about 5gb. With handbreak, if I don't change anything, it will come out about 750mb. However, there is an option I can set lover mb (did it 500mb) but I don't know what resolution. Still wait for ipod to test it out.
Update:
The cable above I bought can't syn the Ipod. However, it can charge and play video fine. I use it with RES with no problem. Got an AC/usb converter ($4). I ordered a different cable ($3) from ebay and using for charge and syn at home. Video files converted from handbreak play fine in Ipod. Very happy with the purchase.
