All speakers stopped working except sub - Honda Pilot - Honda Pilot Forums
Old 03-30-2010, 10:52 AM   #1 (permalink)
Default All speakers stopped working except sub
I've got a '03 w/ RES. Yesterday, lost all sound to speakers except for the sub. When you turn the radio on, there's a very small pop you can hear on the front speakers. The radio itself is still working in that you can hear the sub and if you put the Rear Power on and plug in headphones, you can hear whatever is playing.
Is it a something up w/ the amp and is there anything I can do myself before I take it in and have Honda look at it? Biggest fear is them coming back and saying I need to replace the while unit. Planning on trading it in later this year, so the question then would be would I be better off going factory so the whole system works or going after-market and lose some functionality.
Also, if this has been covered before I apologize. Tried to do a number of different searches to avoid creating a new post but it seems like the search function on the site is pulling limited results. Example....a search on "Speakers" in this forum returned less than 15 results.
dhen is offline   Reply With Quote
Old 03-30-2010, 11:36 AM   #2 (permalink)
I always work on the cheapest possible solution first.
Check fuses. Better yet, replace them with known good fuses.
Old 03-30-2010, 11:47 AM   #3 (permalink)
I checked the Fuse diagram and it only show one that says "Radio" ......nothing for speakers or amp. Since the radio is working, I'm assuming that one's not the problem. I assumed that the speakers would be powered by an internal amp within the radio unit.
