Honda Pilot - Honda Pilot Forums (http://www.piloteers.org/forums/)
-   Maintenance (http://www.piloteers.org/forums/18-maintenance/)
-   -   Have you had an EGR valve problem? (http://www.piloteers.org/forums/18-maintenance/9858-have-you-had-egr-valve-problem.html)
N_Jay 10-10-2004 09:37 AM
Wondering if there is any EVIDENCE (rather than anecdote) that the use of Synthetic oil reduces or eliminates this problem.
gopilot 10-10-2004 02:37 PM
Had mine replaced, I have always had my oil changes done at Honda, so I believe conventional oil is used.
RipRocK 10-11-2004 03:24 AM
Hmmm, I'm surprised to see that there haven't been more votes and comments on this poll. I think it's an interesting and as scientific as you'll get in a forum like this.
I thought about starting a poll like this pertaining to the failure of the EGR valve and the number of Canadian Pilot owners to dispell the myth that the MMT in our gas caused a premature failure of EGR valves. I believe MMT has nothing to do with the rate of EGR valve failures. I think Honda just used crappy components.
Anyway, I don't fall into any categories listed above, but I still chose, "Yes I have had an EGR Replaced, I use Synthetic oil" since when I replaced my EGR valve, I was using synth at the time.
However, I started to experience the symptoms of a bad EGR valve soon after I got my darn Pilot and up until about 16K KM, I used regular oil and switched to synth.
And after an ever exacerbating and frustrating year or so after I switched to synth, I had to keep on driving my Pilot with my EGR valve acting up since none of the GD dealers in town would take it in for a diagnostic test.
Then it finally puked up an error code and the EGR valve was replaced. It's been purring like a cat ever since :D
So, I can't attribute the EGR valve problem I had with having not used nor used the synth oil. But I know once thing for certain, it truly sucks donkey's balls to be driving with a malfunctioning unit for an extended period of time.
Those of you who've had EGR valve problems or will end up with one, count yourself lucky when it throw up a code real quickly, like it did for N_Jay. Might as well have it replaced before your warranty's up if it's gonna fail anyway, rigth?
Sunday Rider 10-11-2004 09:11 AM
Good Poll.
I keep waiting for it to go. My warranty is now up. I have the extended but not sure if the EGR valve is covered.
So far so good. But thanks to RipRock's detailed posts, and other posters, I should be able to recognize it.
Maybe it is time to switch to Synthetic......
beir 10-11-2004 11:53 AM
This may sound like a stupid question but what is an EGR valve?
john802 10-11-2004 12:09 PM
EGR valve - Exhaust Gas Recirculating Valves
Scoobs 10-11-2004 07:10 PM
http://autorepair.about.com/library/.../bldef-165.htm
N_Jay 10-11-2004 08:16 PM
Looky Looky!
No diference between Dino and Syn EGR rates. :4:
Larryl 10-29-2004 06:35 PM
Maybe you should be looking at the TBN at the time of the failure.
N_Jay 10-29-2004 06:40 PM
Why?
charles0176 10-29-2004 07:45 PM
Just exactly what are the symptoms of an EGR valve problem?
N_Jay 10-29-2004 07:56 PM
Typically it is felt as a slight shudder or vibration when at a steady cruise.
When bad it will trip the Check Engine light (MIL) and sometimes the VTM-4 error light.
charles0176 10-30-2004 02:09 PM
Thanks for the info, hopefully it does not happen.
tim.s 10-30-2004 10:54 PM
Re: Have you had an EGR valve problem?
I do now at 42k...getting it replaced next week.
RipRocK 10-30-2004 11:24 PM
Re: Re: Have you had an EGR valve problem?
Darn! What were your symptoms, if any? Is this getting covered under your warranty?
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
